- Mute
- Permalink
- Report
Hi There,
I have just updated to Map3D 2014 and work in 2D Drafting Workspace. In 2013, the export button was located in the Map Drafting tab, Map Output panel. In earlier versions it was under output tab as map 3d export. However, its position in 2014 from 2013 has been replace by a "To FDO Connection". In help, it directs me to the older location of under the output tab - map data transfer - map 3d output, however this does not seem to exist. The only panels I have there are Plot and Export to DWF/PDF, no map data transfer. I can find it if I switch to Map Drafting Workspace in the Map Drafting pulldown - inport/export - export, or if I use the command "mapexport", but from both it only asks where and what to name the file and what type (shp, tab, etc), and then the routine stops and goes back to the drawing instead of opening the dialog to select objects, etc. Can anyone confirm if this is a bug or how to fix please? Some of my clients insist on shp files.
