AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Error in Map 3D's termin?
3 REPLIES 3
georg.grebenyuk
420 Views, 3 Replies
Hi, yesterday I was confused when found mistakes in my geodetic's experiments. Look to MAPCSLIBRARY and parameter named "Eccentricity Squared" in Ellipsoid's properties. F.e. lets look on "World Geodetic System of 1984, GEM 10C"
In Help's guide also it parameter named as "Eccentricity Squared"
Other case - when you going to definition of each coordinate system (f.r. for LL84) it value [0.0818191908426213] name as "Eccentricity". Sorry for Russian screens - my Eng version is failed
For WGS-84 Eccentricity Squared = 0.00669438. And it differences in definition is problem to understand principle of working MAP 3D. Thus - my question, is it problem dealing with only mistake in termin or for value of "Eccentricity Square"?!
Best regards,
Egor Grebenyuk,
JSC "Roszheldorproject", BIM specialist (infrastructure)
3 REPLIES 3
In 2012ru and in 2019en:
In 2012 and 2019, the terms are the same - "Eccentricity."
By the way, it can be seen that from 2012 to 2019 the values changed.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Yeah, in those windows it looks like true, but if you going to any ellipsoids definition - there you will find it value with other name. Problem with differences in "name" and valid value for that "name" of parameter.
Best regards,
Egor Grebenyuk,
Pointdump
in reply to: georg.grebenyuk
Egor,
Good catch. If Eccentricity Squared "Specifies the eccentricity" then I'm confused.
It took me a bit of time to even find the formulas. Best I could find was >>>Here<<<. And then after further reading I find the concepts of "first" and "second" eccentricity and flattening, of which I have no idea.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
