error !dbobji.cpp@8617: eNotOpenForWrite when updating style on layer query
hola,
cuando intento consultar bloques del dibujo actual (por su nombre) y estilizo la capa
puedo observar que sólo se somete al estilo un único bloque;
al tratar de forzar de nuevo la consulta para que lo tengan todos, salta el error y se cierra el programa.
when I try to consult blocks of the current drawing (by name) and I stylize the layer wiith a symbol or an annotation I can see that only one block is submitted to the style;
when trying to force the query again so that everyone has it, the error jumps and the program is closed.
it is useless to recover the file, clean the cache, ...
something prevents the query from continuing after the first result
any ideas?
@Anonymous:
The title of this post was updated by @Thomas_Stuehle to include further details. Previous title: error !dbobji.cpp@8617: eNotOpenForWrite
Thomas_Stuehle
Hello @Anonymous
Thanks for bringing this up.
It is reproducible for the versions 2017 to 2020. For the versions 2015 and 2016 the issue does not appear.
For now, the available workaround is to change the style of single objects instead of several objects at a time.
After reproduction the issue is forwarded internally.  Unfortunately I do not have any influence on the timing of feedback. I will update you once I have new information on this.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
