Does Autocad Map support WFS-t (via Mapconnect)?
patrickvanhoeijen
Message 1 of 9
patrickvanhoeijen
Does Autocad Map support WFS-t (via Mapconnect)? (so not WFS, but WFS-t)
I find this message on autodesk site:
https://knowledge.autodesk.com/support/autocad-map-3d/learn-explore/caas/sfdcarticles/sfdcarticles/W...
However this seems to be 2017. Maybe the current version does?
Replies (8)
Message 2 of 9
Pointdump
Patrick,
What site do you want to test? I can check 2020 version. What version are you using?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 9
patrickvanhoeijen
Just want to know if one of the existing versions supports this. Do you know about that?
Message 4 of 9
braudpat
Hello @patrickvanhoeijen
As said @Pointdump please give us a valid / public WFS-T link to test !?
I can test with ALL versions of MAP (with ALL Updates / Hotfix) : 2021, 2020, 2019, 2018, 2017, 2016, etc ...
Because the WMS/WFS/WMTS FDO drivers of MAP / CIVIL , are "rigid" !
THE HEALTH (Stay Safe, Stay Home, Stay Live), Regards, Patrice (The Retired Old French EE Froggy)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 5 of 9
patrickvanhoeijen
We tested ourselves already, seems to work without error message, however the resultas are empty. So it seems the software still does not support this type.
Unfortunately I cannot give you the link as it is from a customer of ours.
So I am just looking for an answer: the software (and if so which version) supports this or not at all.
Thanks for your reply.
Message 6 of 9
braudpat
It seems you have ACAD MAP 2017 !?
If I remember well, there is maybe a Hotfix for the WMS/WFS 2017 FDO Driver !? ... To check please ??
Patrice BRAUD
Message 7 of 9
braudpat
I have found the Hotfix for MAP 2016/2017/2018 FDO WMS/WFS driver ...
https://knowledge.autodesk.com/support/autocad-map-3d/troubleshooting/caas/sfdcarticles/sfdcarticles...
So uncompress the "WMSSSL.zip" file and replace your 2017 "OWS.DLL" file !
Into "C:\Program Files\Autodesk\AutoCAD 2017\Map\bin\FDO" folder ...
And relaunch MAP 2017 and retest ...
Maybe the solution ? Maybe Not !
Patrice BRAUD
Message 8 of 9
patrickvanhoeijen
I have several versions available, also tried 2020.
Message 9 of 9
braudpat
OK if it is NOK with MAP 2020 (with MAP 2020.0.1 Update), I will assume that there is NO Solution !?
Patrice BRAUD
