- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I used mapimport to bring in parcels as polylines with object data from a .shp file. Then I queried the taxlot numbers and owners of the taxlots. Next I similarly used mapimport in another drawing to bring in address numbers for the taxlots. These came in as closed polylines with the address numbers in the object data for the poly lines. Again I queried the text and made a text style so that the address numbers would display. I went to check how the address numbers would align with the taxlot numbers. So I attached the taxlot drawing as an XREF, but the queried text did not display. I tried using basic modify copy of the taxlot numbers but nothing occurs. I did a select all of the taxlot numbers and copied to clip board. I used paste to original coordinates but nothing occurred.
It appears that in the og drawings the queried text is not actually a text object but a label that only displays in the og drawing. This is going to be a problem since the purpose of these is to make a base map xref for infrastructure designs.
Is there a way to detach the text such that it behaves as strictly a text object? Drawings are attached.
Thank you,
Ammon
Attached are the two drawings I described. Owner has the parcel polylines and address is only the address number polylines.
