Delay in selecting objects in AutoCAD Map 3D 2016
When I try to select several objects, lines, etc. there is constantly a delay (1.5 to 2 seconds) before I can select the next one or before I can enter a command. I never had this problem in Autocad Map 2013.
Murph_Map
Does this happen in all dwgs or just a few? Are there FDO files connected to the dwg(s)?
Murph
Supporting the troops daily.
O_Eckmann
2 tests you can try :
If you have properties palette opened, try to close it.
If you have XRef, try to unload it.
Olivier
Olivier Eckmann
braudpat
Hello
+1 with Olivier
Try to unload ALL XREFs: DWGs, Images, DGNs, PDFs, DWFs ...
Never let OPEN the properties palette if many hatches (2000-10000) are selected
and IDEM for others entities (4000-40000) depending on the speed of your PC !?
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Thank you for your reply.
There seems to be a conflict between the latest update of Microsoft Windows and the BGT-palette that I am using. Our ICT-provider is going to solve this.
Thanks.
