AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Cut off a solid with another solid
3 REPLIES 3
john_daues
510 Views, 3 Replies
I want the horizontal box to be only the part within the cylinder.
I've tried trim and subtract, but those don't work.
How do I do this?
3 REPLIES 3
ChicagoLooper
in reply to: john_daues
Make a 'temporary' solid donut shaped object. The donut hole (empty space) will be the exact same diameter as the cylinder. Position the donut so the cylinder is inside the donut hole. Make the height, or the thickness, of the donut taller than the cylinder.
Subtract command:
Horizontal box - Donut = What you want..
Chicagolooper
O_Eckmann
Hi @john_daues
I think you make a temporary cylinder sized to inner your cylinder, and use INTERSECT to obtain what you want.
Olivier
Olivier Eckmann
jdaues
in reply to: O_Eckmann
Thanks!
