I'm trying to create contours from a .tif that I imported using Data Connection. I've watched several videos on how to do this and each time after using the "Create Contour Layer" command the initial contours are created, the contours reach to the end of the .tif and stop. Mine, form a closed polyline that is driving down to 0 ft. Does anyone know why mine does this and others don't.
First image shows what I'm expecting to see. Second shows what I'm actually getting.
I'm not sure why I get the apron around my site (Green Pic). I've tried clipping the area but the apron continues to be there. I used QGIS to do the clipping.
I'm new to all this. I'm trying to get a better handle on how to use efficiently GIS data from different sources.
Solved by ChicagoLooper. Go to Solution.
Solved by parkr4st. Go to Solution.
Hi Danny,
"...form a closed polyline that is driving down to 0 ft."
I keep looking at your 2nd pic, but I still don't understand.
What version/year is your Map 3D/Civil 3D? Do you have all updates?
Can you post a link to your original data?
Dave
Dave Stoll
Las Vegas, Nevada
Danny,
Thanks for posting your data.
Wow, I've never seen this before. I created a surface in Civil 3D with your Tiff, and look at this edge.
Dave
Dave Stoll
Las Vegas, Nevada
And creating contours in QGIS produces this:
Dave
Dave Stoll
Las Vegas, Nevada
finish the task. mapimport the contours with OD, save the dwg, attach to a new map, set CS, query in all and alter properties Elevation:elevation@contour and draw/execute.
The lines will be at elevation and you will see the ends of the lines that go down in your work and cause concern are now at elevation, i.e. horizontal.
TRIM those ends off if you don't want them.
see attached dwg.
Dave
Hi @dhouleAVYFD
Las Cruces, correct?
The collar of the raster (what you refer to as the apron) does not represent the surface of the earth and contains no elevation value. Therefore it will default to 0 feet above mean sea level if it's included during the creation of your contours.
To use your raster and create contours that won't drop down to 0ft, add your raster as a Feature Data Object (FDO) connection, then do this.
<<The cut off portion has NOT been deleted, it's hidden. To make the hidden part reappear, zoom out, way out(!) so the entire raster can 'fit' in the viewable area of modelspace. Use judgement to determine how far you must zoom out. Next, right click the raster in the Task Pane=>select Resample raster. If the original raster is able to 'fit' inside this new zoomed out 'viewable' area, it will resize itself to its former size which, of course, will include the collar.>>
HINT: Add '_20ft' to the end of your contour's name so it includes the contour interval you specified. Your contour interval may vary.>>
6.The contours will be automatically added to modelspace ( depending on the size of the resample, it may take a few seconds for the contours to generate). You may control the appearance of these contours in the Style Editor by selecting the contour layer in the Task Pane=>Click the Style icon at the top of the Task Pane. See image-6.
NOTES:
Chicagolooper
Hello
When you have 2D PLines with Elevation as Object Data, you can elevate quickly
Plines to the right Z with a Lisp routine "OD2DXF38" ...
Thanks to @CADaSchtroumpf / Bruno for this beautiful routine !
The Health, Bye, Patrice (The Old French EE Froggy)
Patrice BRAUD
Hi ChicagoLooper. Your advice is fantastic by the way. What if your collar is not a rectangular shape, rather a crazy polygon shape? I am getting contours dropping all the way from 15 to -10000 meters, all around my .tif file.
Hi Hieu,
Can you post your crazy Tiff?
Dave
Dave Stoll
Las Vegas, Nevada
<<...What if your collar is not a rectangular shape, rather a crazy polygon...>>
It sounds like you're dealing with drone captured data where the pilot only flies the minimal area, just enough to cover the necessary area. Why pilots can't fly more than the needed area is beyond me. Maybe it's a battery issue. Batteries are heavy and the smaller and lighter the battery the better. To keep the weight down, fly times may only last 15-20 minutes when using lighter batteries. I've spoken with licensed pilots who operate drone/software packages exceeding 6-figures, where the software itself accounts for +75% of the cost. No, no, it's not the kind of drone you buy from an online retailer!
You still might be able to do it if your 'area' that you want contours can be defined by a rectangle AND that rectangle can comfortably 'fit inside' the crazy polygonal shape. If you need the entire polygonal area then your options are limited.
Chicagolooper
Thanks.
Yes, it is drone data and an irregular shape which represents the parcels of land requested. When the .tif/DEM file is imported into AutoCAD Map 3D, it applies an apron around the polygon area of data and gradually drops the elevation values to -9999 and then fills in all the blank space within the North/East/South/West parameters of the .tif. Therefore, when I generate 1m contour intervals I get 10000 contour lines surrounding the polygon shaped .tif data, which is a pain and slows down my machine.
I'm working through generating the contours in QGIS which doesn't apply contours around the apron of the .tif, it's just proving hard to get the contours 'cleaned up'.
Hi Hieu,
Dense contours at the edge, I've seen this before.
Here's some ideas to kick around:
In QGIS use Pixels_2_Points, which gives you a point with elevation at the center of each pixel.
In LASTools use DEM.Zip to convert your Tiff to LAZ point cloud. You might also be able to get your hands on the original point cloud data.
Dave
Dave Stoll
Las Vegas, Nevada
You can eliminate the 'apron' by zooming-IN so the apron is off screen then perform RESAMPLE RASTER. (See post #8.) You'll need to determine how much of the DEM/tif to hide before resampling. Don't be so fast in saying you need every square meter of the tif if you can get away with just 80%-90% of it, e.g. 80% is not 100%.
If you're an advanced user, you can resample then create multiple DEM/tif TILES. Then generate contours tile-by-tile.
Whatever program you use to create contours, however, your biggest problem sounds like you're freely accepting the default interval. You don't necessarily have to accept that default, you're in control so you can increase it, e.g. 10, 20, or 50 so you'll have fewer contours and an easier time panning and zooming. And since you're in control, you may rerun the contours again at a tighter interval, but not so tight that it diminishes performance.
Do you have a small site, for example less than 5,000 square meters? Contrary to popular belief, super tight contours don't add any value to your drawing. It's overkill! A super big subdivision, for example, may only need 5m interval or maybe 10m. If your site is relatively flat, however, then tighter intervals at 2m might be feasible since flat areas generate only a few contours widely spaced apart.
You may also consider running 'spaced-out' contours for the overall entire site map and create additional contours when zooming-in on specific parcels. Limiting tighter contours to only certain parcels and not the entire site will improve performance.
You can change the interval. You can run as many sets of contours as you wish. You're in control.
Chicagolooper
