Create Object Data Table From WFS Connection
Map 3D 2018, Win 7
I connected to our GIS with a WFS connection. I want to extract the object data in order to create an Object Data Table for when I import future data using field survey data and Map 3D by assigning the object data before passing it on to the GIS managers in the form of shape files. Is this possible?
thanks
Murph_Map
David,
See if you can save the WFS connection as an SDF layer. Then you can import that sdf file in your dwg and create OD table on import.
Murph
Supporting the troops daily.
Koesti
Autodesk Support
Autodesk Support
Hi @Anonymous,
yes, it is possible to connect to WFS and export the data via Layer (screenshot) to SDF or SQLite or use bulk copy for other formats, like SHP.
If you only need the object data - use the export to CSV in data table.
Kind regards
Brigitte
Brigitte Koesterke
Technical Support Senior Specialist
