converting dwg to kml
hi
how can i convert dwg to kml file
i am trying to create a polygonfile to import it into a surveing drone
АлексЮстасу
MAPEXPORT - 2020, 19.
PUBLISHKML - 2012, 11, 10, 09, 08, ... (?)
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
i am using autocad map 3d 2015
i did not find kml extension in mapexport
see attached
TerryDotson
If you were to consider third party add-ons, the GeoLocation Plus package is very low cost.
Pointdump
Hasan,
Good question. In Civil 3D the ToolBox Tab allows Export to KML, but I don't know if Map 3D has any way.
I would use MAPEXPORT to get a Polygon Shapefile, then in QGIS convert it to KML.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
ChicagoLooper
You can do this. All you need is Map 3D and Google Earth Pro (don’t confuse GE Pro with Google Maps that you open in your browser, GE Pro is a stand alone program).
Use MAPEXPORT to export your polygons to SHAPEFILE. If you also have points and lines, you’ll have to perform separate exports, one for each type. One for polygons, one points, and another for lines. Name and save your exported shapefile(s).
In Google Earth Pro, go to File=>Import=>Browse to and select your newly created shapefile=>Open.
Your shapefile will appear in the GE Pro map. If not, scroll to very bottom of the PLACES panel. In temporary section, make sure the box next to your shapefile is checked.
To save your shapefile as a kml, right-click your shapefile in the temporary section of Places panel and select Save Place As so you can save it in folder with kml (or kmz) extension.
Chicagolooper
