I was so slow I didn't catch on till reading your reply. I have never used the weed, in either way. So what does the Weed Command do? I read the help and thought it was only for 3D. When I tried using it, I got 'confused' with the angle parameters. However, I use the simplify quite a bit to take out the enormous amount of vertices put into plines which were originally created as splined lines. I found that the simplify to one tenth foot cut down file size by 80 percent.
May have wandered slightly from post. So have yet to use it for the flattening of lines. Will try it next time instead of the "Flatten Command" which I have previously been using for many years.
Till later ,Jim
