Command line units
Command line units
nwesselS8RV5
Observer Observer
Command line units
nwesselS8RV5
Observer
Observer
I'm using AutoCads Geo Distance tool to measure the distance between two gps points. I want the distances to be displayed in Feet and Inches, but no matter what i have tried, the values displayed in the command line remain in Decimal Feet and not feet and inches.
I've tried switching to Architectural in the Length Type field to no avail. Is this just something i have to live with or am i missing something?
For example: The above distance is 33.8236 ft, which converts roughly to 33'-10". Is there a way to get the command line to display that distance as 33'-10"
ChicagoLooper
Hi @nwesselS8RV5
The solution is not found in Command Line Units.
Are you using a coordinate system (CS) that has feet? If you're dealing with GPS points, then you M-U-S-T have an 'assigned' coordinate system in your drawing. If you don't assign one then your GPS points may appear anywhere on Earth. Your site location has at least one 'appropriate' coordinate system and you must pick one and assign it to your drawing.
If you accidentally change the Drawing Units of your map, then your GPS coordinates will not have their correct northing and eating values.
Your length/distances will adopt or inherit the units of your assigned CS….and CS's are either in feet or meters, not feet-and-inches, never ever.
If you're using State Plane Coordinate System (SPCS) then your units of measurement will be feet. However, if you're using WGS84/epsg 4326, then your units of measurement will be degrees, such as Lat/Longs, and that's a no-no because no one uses 'degrees' to describe a length. Length is typically expressed in feet or meters, not degrees
Don’t be mistaken, it’s OK to input you’re GPS points as degrees into a drawing with an assigned CS that uses feet. Map3D knows how to transform their positions and make them land accurately. This is all part of geospatial drawing which does NOT require your input units to match the assigned CS units.
If you want to find length (or distances) in feet and inches in your drawing with those GPS coordinates then you can create (or establish) a Dimension Style with the parameters like those shown on the Primary Units tab. Refer to image shown below.
Below, you can see the Dimension Style displays 90'-0". You may put this dimension on a brand new layer that you may turn ON or OFF. Or you may delete the dimension altogether once you've seen it.102.PNG
Chicagolooper
nwesselS8RV5
Observer
Observer
Yes I am using a CS that has US survey feet.
I will give the Dim Styles workaround a try and let you know how that works out for me.
Appreciate the response!
