Collecting card-objects for later (re-)usage?
ab_c
Message 1 of 1
ab_c
For Map 2018, Oracle Industry Model
Workflow as example:
I'm working in my drawing and find an object which has to be modified. I know that there are other elements too which I will find and which need the same modification. So I don't want to modify every single object alone; I want to "collect" them and modify them at the end globally. To "select and collect them with mouseclick" is not possible, because every other command or an ESC will skip the collection.
With pure Autocad-elements I would you "selection sets ss", but - is there a way for MAPBULKFEATUREs?
Replies (0)
