AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Can't install autocad map 3D
4 REPLIES 4
942 Views, 4 Replies
Hello guys,i have a problem and that is as i said in the title that i can't install autocad map 3D.I already have autocad 2015 x64 and raster design x64 2015
and i am running it on windows 10.Here it is the installation log :
2017/1/17:19:59:09 soram DESKTOP-NHHVNDD === Setup started on DESKTOP-NHHVNDD by soram ===
2017/1/17:19:59:09 soram DESKTOP-NHHVNDD Path_Length: 157
2017/1/17:19:59:09 soram DESKTOP-NHHVNDD Current Directory C:\Autodesk\Autodesk_Map_2015_R1_English_Win_64bit_WI_en-us
2017/1/17:19:59:09 soram DESKTOP-NHHVNDD Launch
2017/1/17:19:59:09 soram DESKTOP-NHHVNDD CommandLine /akamai /sid a1b3A00000A9u6NQAR /skipEULA /skipPI /url "http://efulfillment.autodesk.com/SWDLDNET4/2015/MAP/WI/Autodesk_Map_2015_R1_English_Win_64bit_WI_en-..."
2017/1/17:19:59:09 soram DESKTOP-NHHVNDD Current Directory C:\Users\soram\AppData\Local\Temp\_AI9D49.tmp
2017/1/17:19:59:31 soram DESKTOP-NHHVNDD === Setup ended ===
2017/1/17:19:59:10 soram DESKTOP-NHHVNDD === Setup started on DESKTOP-NHHVNDD by soram ===
2017/1/17:19:59:10 soram DESKTOP-NHHVNDD Path_Length: 157
2017/1/17:19:59:10 soram DESKTOP-NHHVNDD Current Directory C:\Users\soram\AppData\Local\Temp\_AI9D49.tmp
2017/1/17:19:59:10 soram DESKTOP-NHHVNDD Launch
2017/1/17:19:59:31 soram DESKTOP-NHHVNDD Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/SETUP_...
2017/1/17:19:59:31 soram DESKTOP-NHHVNDD Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\soram\AppData\Local\Temp\_AI9D49.tmp\Setup\AcSetup.dll
2017/1/17:19:59:31 soram DESKTOP-NHHVNDD Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/1/17:19:59:31 soram DESKTOP-NHHVNDD PageOpen LaunchDialog
2017/1/17:20:00:02 soram DESKTOP-NHHVNDD PageOpen LicenseDialog
2017/1/17:20:00:02 soram DESKTOP-NHHVNDD PageOpen ProductInfoDialog
2017/1/17:20:02:23 soram DESKTOP-NHHVNDD PageOpen ProductSelectionDialog2
2017/1/17:20:02:28 soram DESKTOP-NHHVNDD PageOpen FullProgressDialog
2017/1/17:20:02:28 soram DESKTOP-NHHVNDD Download Skipped VCREDIST2012X86UPD4 http://efulfillment.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/VCREDI...
2017/1/17:20:02:28 soram DESKTOP-NHHVNDD Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\soram\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/1/17:20:02:33 soram DESKTOP-NHHVNDD Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2017/1/17:20:02:33 soram DESKTOP-NHHVNDD Download Skipped VCREDIST2012X64UPD4 http://efulfillment.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/VCREDI...
2017/1/17:20:02:33 soram DESKTOP-NHHVNDD Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\soram\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/1/17:20:02:39 soram DESKTOP-NHHVNDD Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2017/1/17:20:02:39 soram DESKTOP-NHHVNDD Download Skipped DIRECTX http://efulfillment.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/DIRECT...
2017/1/17:20:02:39 soram DESKTOP-NHHVNDD Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/17:20:02:41 soram DESKTOP-NHHVNDD Install DirectX Runtime Succeeded
2017/1/17:20:02:41 soram DESKTOP-NHHVNDD Installing Microsoft SQL Server Native Client 11.0: IACCEPTSQLNCLILICENSETERMS=YES ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2015" SETUP_PACKAGECODE={B4C0BF45-1B56-4F43-A5B2-73A8D9230ACB} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/17:20:02:42 soram DESKTOP-NHHVNDD Install Microsoft SQL Server Native Client 11.0 Succeeded
2017/1/17:20:02:42 soram DESKTOP-NHHVNDD Download Skipped ACADMAP http://efulfillment.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/ACADMA...
2017/1/17:20:02:42 soram DESKTOP-NHHVNDD Installing Autodesk® AutoCAD® Map 3D 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015\x64\en-us\acadmap\acadmap.mst;C:\Users\soram\AppData\Local\Temp\_AI9D49.tmp\x64\acadmap\acadmap-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/17:20:05:40 soram DESKTOP-NHHVNDD Install Autodesk® AutoCAD® Map 3D 2015 Succeeded
2017/1/17:20:05:41 soram DESKTOP-NHHVNDD Download Play ACADMAP_en-us http://efulfillment.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/ACADMA...
2017/1/17:20:05:54 soram DESKTOP-NHHVNDD Download Aborted ACADMAP_en-us http://efulfillment.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/ACADMA...
2017/1/17:20:05:54 soram DESKTOP-NHHVNDD Install Autodesk® AutoCAD® Map 3D 2015 Language Pack Failed Download Failed, Installation aborted, Result=1603
2017/1/17:20:06:24 soram DESKTOP-NHHVNDD Rollback Autodesk® AutoCAD® Map 3D 2015 Succeeded
2017/1/17:20:06:24 soram DESKTOP-NHHVNDD Rollback Microsoft SQL Server Native Client 11.0 Succeeded
2017/1/17:20:06:24 soram DESKTOP-NHHVNDD Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/1/17:20:06:24 soram DESKTOP-NHHVNDD Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2017/1/17:20:06:24 soram DESKTOP-NHHVNDD Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2017/1/17:20:06:25 soram DESKTOP-NHHVNDD PageOpen InstallCompleteDialog
2017/1/17:20:08:43 soram DESKTOP-NHHVNDD === Setup ended ===
2017/1/17:20:10:06 soram DESKTOP-NHHVNDD === Setup started on DESKTOP-NHHVNDD by soram ===
2017/1/17:20:10:06 soram DESKTOP-NHHVNDD Path_Length: 157
2017/1/17:20:10:06 soram DESKTOP-NHHVNDD Current Directory C:\Autodesk\Autodesk_Map_2015_R1_English_Win_64bit_WI_en-us
2017/1/17:20:10:06 soram DESKTOP-NHHVNDD Launch
2017/1/17:20:10:06 soram DESKTOP-NHHVNDD CommandLine /URL "http://efulfillment.autodesk.com/SWDLDNET4/2015/MAP/WI/Autodesk_Map_2015_R1_English_Win_64bit_WI_en-..." /skipPI /akamai
2017/1/17:20:10:06 soram DESKTOP-NHHVNDD Current Directory C:\Users\soram\AppData\Local\Temp\_AIA315.tmp
2017/1/17:20:10:07 soram DESKTOP-NHHVNDD === Setup ended ===
2017/1/17:20:10:06 soram DESKTOP-NHHVNDD Download Skipped SETUP_CONFIG http://efulfillment.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/SETUP_...
2017/1/17:20:10:07 soram DESKTOP-NHHVNDD Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\soram\AppData\Local\Temp\_AIA315.tmp\Setup\AcSetup.dll
2017/1/17:20:10:07 soram DESKTOP-NHHVNDD Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/1/17:20:10:07 soram DESKTOP-NHHVNDD PageOpen LaunchDialog
2017/1/17:20:10:17 soram DESKTOP-NHHVNDD PageOpen LicenseDialog
2017/1/17:20:10:22 soram DESKTOP-NHHVNDD PageOpen ProductInfoDialog
2017/1/17:20:10:58 soram DESKTOP-NHHVNDD PageOpen ProductSelectionDialog2
2017/1/17:20:11:00 soram DESKTOP-NHHVNDD PageOpen FullProgressDialog
2017/1/17:20:11:00 soram DESKTOP-NHHVNDD Download Skipped VCREDIST2012X86UPD4 http://efulfillment.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/VCREDI...
2017/1/17:20:11:00 soram DESKTOP-NHHVNDD Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\soram\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/1/17:20:11:00 soram DESKTOP-NHHVNDD Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2017/1/17:20:11:00 soram DESKTOP-NHHVNDD Download Skipped VCREDIST2012X64UPD4 http://efulfillment.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/VCREDI...
2017/1/17:20:11:00 soram DESKTOP-NHHVNDD Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\soram\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/1/17:20:11:00 soram DESKTOP-NHHVNDD Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2017/1/17:20:11:00 soram DESKTOP-NHHVNDD Download Skipped DIRECTX http://efulfillment.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/DIRECT...
2017/1/17:20:11:01 soram DESKTOP-NHHVNDD Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/17:20:11:03 soram DESKTOP-NHHVNDD Install DirectX Runtime Succeeded
2017/1/17:20:11:03 soram DESKTOP-NHHVNDD Installing Microsoft SQL Server Native Client 11.0: IACCEPTSQLNCLILICENSETERMS=YES ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2015" SETUP_PACKAGECODE={B4C0BF45-1B56-4F43-A5B2-73A8D9230ACB} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/17:20:11:04 soram DESKTOP-NHHVNDD Install Microsoft SQL Server Native Client 11.0 Succeeded
2017/1/17:20:11:04 soram DESKTOP-NHHVNDD Download Skipped ACADMAP http://efulfillment.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/ACADMA...
2017/1/17:20:11:05 soram DESKTOP-NHHVNDD Installing Autodesk® AutoCAD® Map 3D 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015\x64\en-us\acadmap\acadmap.mst;C:\Users\soram\AppData\Local\Temp\_AIA315.tmp\x64\acadmap\acadmap-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/17:20:14:48 soram DESKTOP-NHHVNDD Install Autodesk® AutoCAD® Map 3D 2015 Succeeded
2017/1/17:20:14:48 soram DESKTOP-NHHVNDD Download Play ACADMAP_en-us http://efulfillment.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/ACADMA...
2017/1/17:20:15:00 soram DESKTOP-NHHVNDD Download Aborted ACADMAP_en-us http://efulfillment.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/ACADMA...
2017/1/17:20:15:00 soram DESKTOP-NHHVNDD Install Autodesk® AutoCAD® Map 3D 2015 Language Pack Failed Download Failed, Installation aborted, Result=1603
2017/1/17:20:15:29 soram DESKTOP-NHHVNDD Rollback Autodesk® AutoCAD® Map 3D 2015 Succeeded
2017/1/17:20:15:30 soram DESKTOP-NHHVNDD Rollback Microsoft SQL Server Native Client 11.0 Succeeded
2017/1/17:20:15:30 soram DESKTOP-NHHVNDD Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/1/17:20:15:30 soram DESKTOP-NHHVNDD Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2017/1/17:20:15:30 soram DESKTOP-NHHVNDD Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
2017/1/17:20:15:30 soram DESKTOP-NHHVNDD PageOpen InstallCompleteDialog
2017/1/17:20:19:24 soram DESKTOP-NHHVNDD === Setup ended ===
2017/1/18:12:57:51 soram DESKTOP-NHHVNDD === Setup started on DESKTOP-NHHVNDD by soram ===
2017/1/18:12:57:51 soram DESKTOP-NHHVNDD Path_Length: 157
2017/1/18:12:57:51 soram DESKTOP-NHHVNDD Current Directory C:\Autodesk\Autodesk_Map_2015_R1_English_Win_64bit_WI_en-us
2017/1/18:12:57:51 soram DESKTOP-NHHVNDD Launch
2017/1/18:12:57:51 soram DESKTOP-NHHVNDD CommandLine /PK 129G1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/Autodesk_Map_2015_R1_English_Win_64bit_WI_en-us_S..."
2017/1/18:12:57:51 soram DESKTOP-NHHVNDD Current Directory C:\Users\soram\AppData\Local\Temp\_AI4328.tmp
2017/1/18:12:58:19 soram DESKTOP-NHHVNDD === Setup ended ===
2017/1/18:12:57:52 soram DESKTOP-NHHVNDD === Setup started on DESKTOP-NHHVNDD by soram ===
2017/1/18:12:57:52 soram DESKTOP-NHHVNDD Path_Length: 157
2017/1/18:12:57:52 soram DESKTOP-NHHVNDD Current Directory C:\Users\soram\AppData\Local\Temp\_AI4328.tmp
2017/1/18:12:57:52 soram DESKTOP-NHHVNDD Launch
2017/1/18:12:58:14 soram DESKTOP-NHHVNDD Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/SETUP_x64....
2017/1/18:12:58:18 soram DESKTOP-NHHVNDD Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/SETUP_x64....
2017/1/18:12:58:18 soram DESKTOP-NHHVNDD Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\soram\AppData\Local\Temp\_AI4328.tmp\Setup\AcSetup.dll
2017/1/18:12:58:18 soram DESKTOP-NHHVNDD Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/1/18:12:58:18 soram DESKTOP-NHHVNDD PageOpen LaunchDialog
2017/1/18:12:58:43 soram DESKTOP-NHHVNDD PageOpen LicenseDialog
2017/1/18:12:58:43 soram DESKTOP-NHHVNDD PageOpen ProductInfoDialog
2017/1/18:12:58:43 soram DESKTOP-NHHVNDD PageOpen ProductSelectionDialog2
2017/1/18:12:59:14 soram DESKTOP-NHHVNDD PageOpen FullProgressDialog
2017/1/18:12:59:15 soram DESKTOP-NHHVNDD Download Play VCREDIST2012X86UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/VCREDIST20...
2017/1/18:12:59:16 soram DESKTOP-NHHVNDD Download Complete VCREDIST2012X86UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/VCREDIST20...
2017/1/18:12:59:16 soram DESKTOP-NHHVNDD Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\soram\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/1/18:12:59:16 soram DESKTOP-NHHVNDD Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2017/1/18:12:59:16 soram DESKTOP-NHHVNDD Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/VCREDIST20...
2017/1/18:12:59:17 soram DESKTOP-NHHVNDD Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/VCREDIST20...
2017/1/18:12:59:17 soram DESKTOP-NHHVNDD Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\soram\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/1/18:12:59:18 soram DESKTOP-NHHVNDD Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2017/1/18:12:59:18 soram DESKTOP-NHHVNDD Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/DIRECTX.ta...
2017/1/18:12:59:20 soram DESKTOP-NHHVNDD Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/DIRECTX.ta...
2017/1/18:12:59:20 soram DESKTOP-NHHVNDD Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/18:12:59:23 soram DESKTOP-NHHVNDD Install DirectX Runtime Succeeded
2017/1/18:12:59:23 soram DESKTOP-NHHVNDD Installing Microsoft SQL Server Native Client 11.0: IACCEPTSQLNCLILICENSETERMS=YES ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Map 3D 2015" SETUP_PACKAGECODE={B4C0BF45-1B56-4F43-A5B2-73A8D9230ACB} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Map 3D 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/1/18:12:59:24 soram DESKTOP-NHHVNDD Install Microsoft SQL Server Native Client 11.0 Succeeded
2017/1/18:12:59:24 soram DESKTOP-NHHVNDD Download Play ACADMAP http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/ACADMAP_x6...
2017/1/18:13:00:07 soram DESKTOP-NHHVNDD Download Aborted ACADMAP http://edutrial.autodesk.com/SWDLDNET4/2015/MAP/WI/{6B0E813E-7B16-4EBC-86E1-7070253C14A9}/ACADMAP_x6...
2017/1/18:13:00:07 soram DESKTOP-NHHVNDD Install Autodesk® AutoCAD® Map 3D 2015 Failed Download Failed, Installation aborted, Result=1603
2017/1/18:13:00:08 soram DESKTOP-NHHVNDD Rollback Microsoft SQL Server Native Client 11.0 Succeeded
2017/1/18:13:00:08 soram DESKTOP-NHHVNDD Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/1/18:13:00:08 soram DESKTOP-NHHVNDD Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2017/1/18:13:00:08 soram DESKTOP-NHHVNDD Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
Plz help,i need it asap !Thank you (I also tried to clean the registery)
4 REPLIES 4
Gary_Braun
This can happen if you have a service pack integrated into your deployment image. If you do then remove it and try again.
http://upandready.typepad.com/up_and_ready/2015/03/deploying-language-pack-for-autocad-fails-with-er...
in reply to: Gary_Braun
"This can happen if you have a service pack integrated into your deployment image. If you do then remove it and try again." I don't understand what you mean.Can you be a little more specific? How do i found out if i have a service pack integrated into my deployment image and how do i remove it if i have it?
Gary_Braun
When you launch the installer you will get a choice to install locally or create a deployment, but you should also be able to edit your existing deployment and remove any service packs that may be streamed into the administrative image. Best thing to do is take a look at the online help.
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/Autodesk-NetworkAdmin...
Ty for help guys,i don't know what i did but it worked and now i have it installed.
