I am attempting to connect to our Esri Enterprise database using the OSGeo FDO, but it consistently fails.
I'm wondering if the problem lies with the instance name. What does Autocad consider that to be in a Postgres environment? As far as I understand things in Postgres, the instance is the same as the cluster name. Does that apply here? What is the instance name supposed to be in a Postgres environment?
Given that it's Postgres, I've also tried this https://knowledge.autodesk.com/support/autocad-map-3d/troubleshooting/caas/sfdcarticles/sfdcarticles...
even though I think it only applies to direct non-Esri connections.
