Blank Coordinate System Library
Pointdump
Consultant Consultant
Pointdump
My Coordinate System Library is broken. Nothing in the list in both C3D 2014 and C3D 2015.
In C3D 2016 and Map 3D 2016, everything is there and works fine.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Alfred.NESWADBA
have you had defined any manual coordinate systems? If so my guess is they are stored with informations which can't be interpreted/evaluated (whatever word is correct here) from these versions of Map3D/Civil3D.
Take a look in that directory (if it exists):
    C:\Users\<your login name>\AppData\Local\Autodesk\User Geospatial Coordinate Systems
whereas "AppData" is a hidden folder, you have to type that in or ensure in Windows Explorer settings you can see hidden folders.
If you do have any files in here then move them away to a secure place so you have a backup, but this folder is empty.
When you start now Civil3D2014/2015 is the MAPCSLIBRARY dialog again empty?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Pointdump
Hi Alfred,
Yes, I've been playing with Low-Distortion Projections. I'll try your suggestion right now and see if I can find the culprit.
Thank you.
Dave
Dave Stoll
Las Vegas, Nevada
Pointdump
Alfred,
I pulled these two files out of my User Geospatial Coordinate Systems Folder, but they just magically re-appear, and my Library is still blank:
Dave
Dave Stoll
Las Vegas, Nevada
Pointdump
Alfred,
OK, now I deleted, instead of just moving, those two files. That seemed to work. I'll play with it further, but I think you definitely put your finger on the problem.
Thank you.
Dave
Dave Stoll
Las Vegas, Nevada
Alfred.NESWADBA
Wow, can't imagine why that happens .... ahh one option maybe: have you had opened (during the tests) a drawing with a user specified coordinate system? ...(so Map 3D checks that coordinate system in the drawing as "unknown" and so stores the definition again in the user coord folder.
- alfred -
Alfred NESWADBA
Pointdump
Alfred,
"...Map 3D checks that coordinate system in the drawing as "unknown" and so stores the definition again in the user coord folder."
I think that was what was happening.
Dave
Dave Stoll
Las Vegas, Nevada
