AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCAD problems
6 REPLIES 6
753 Views, 6 Replies
AutoCAD problems
My drawings keep crashing.   I will be in the middle of a command and the drawing will disappear, leaving me with a black area.  When I move the mouse around random lines appear and disappear again.  What is going on?  My computer was recently formatted, and it is still occurring.  Is anyone else experiencing this?
6 REPLIES 6
parkr4st
what is your op sys, autocad version & vertical and have you updated all of the software,  videocard, proscessor and memory?
in reply to: parkr4st
I'm using AutoCAD map 3D 2009.  All software should be up to date.  My vertical?  What do you mean?
parkr4st
what beyond basic autocad you use . Map 3d is it.
my guess you have memory issue or possibly a video card issue.  Did you have the problem prior to refromatting the computer?  what windows version do you use now versus pre formatting?
dave
Yes, I was having the problem before formatting,  I believe the Windows version is the same as it was before as well.  I don't know what version though...WindowsXP?  No one else in the office is having the same problem, and everything was loaded the same.  My drawings that crash can be opened by other people without issues.
I have switched computers as well.  The problem occured on my first computer, so I got a reformatted one from somewhere else.  Both have had the issues.
AllenJessup
Have you tried using the Audit or Recover command on the drawings?
Allen
Allen Jessup
CAD Manager - Designer
