The workspace will open, but immediately freeze. The same happens whether I start the software first or double click a file. I tried the solution in the forum post:
The solution did not work.
I should note that the AutoCAD software freezes, not Windows. I have to use the task manager to force stop AutoCAD.
Josh,
Welcome to the Autodesk Forums!
Is this a new installation of AutoCAD? What version of AutoCAD? Are you up to date on Service Packs?
Dave
Dave Stoll
Las Vegas, Nevada
Yes, of course. I should have given this info.
This is a new install of AutoCAD Map 3D 2016 on a laptop with an Intel 64 bit Core i7-2760 @ 2.4GHz with 16gb RAM and the NVIDIA Quadro 1000M display adaptor.
I'm running the fully updated and current version of Windows 10 Pro. AutoCAD Map 3D is also updated and has the service packs installed.
Thanks in advance for any help!
Josh,
Dunno. Are you on a Network of any kind? All I can think of is to try RESET:
Dave
Dave Stoll
Las Vegas, Nevada
Thanks for the quick response!
I never had the opportunity to set any settings other than selecting the workspace. I tried this anyway as per your suggestion. I reset and tried each of the workspace options. All still end in the same result of a frozen and empty workspace.
So, it's still not working.
Josh,
Looks like a complete re-install is in your future. Maybe someone will chime in with something brilliant.
Dave
Dave Stoll
Las Vegas, Nevada
Unfortunately, I performed the complete uninstall/reinstall last night before starting this thread. It did not help.
Hello
1) Is ACAD (ACAD commands NOT MAP commands) running correctly ?
2) It it only the MAP Workspace which is the problem ?
Regards, Patrice
Patrice BRAUD
do you rest your AutoCAD Profile to default?
Thats because the deinnstallation not delete every user profile of AutoCAD Map 3D.
Issues inside the user Profile can crashes many commands inside AutoCAD.
You will find it in your start menu at the same place as starting AutoCAD Map.
Thorsten - Contelos GmbH
Hi!
Did you get your problem solved?
I've just the same with Windows 10, Map 3D 2017 (newest Service Pack & Hotfixes).
Thanks for a response!
