AutoDESK 's latest release of 2024 and the SDE connection to PostgreSQL is still malfunctioning.
FYI - Testing was done on AutoCAD Map 3D 2020, 2021 and 2024. We attempted the following solution (see URL below) as recommended by AutoDESK customer service when we opened the ticket but it did not resolve the issue. Do not know if it ever worked for anyone else 🤷:male_sign:
Unable to load the FDO Provider library ‘PostgreSQLProvider.dll’" in Map 3D or Civil 3D 2019
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Connection-to-Post...
A failed connection still occurred. Running Version 14.5 for PostgreSQL.
Waiting on AutoDESK developers for a fix. so I can access data from my SDE. Original case no. ticket was logged back in Q3 - Oct 2023. It was flagged as a bug but still no word.
