AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCAD Map 3D 2015 SP3 not working with 2015 Industry model
2 REPLIES 2
330 Views, 2 Replies
Dear All,
I updated my AutoCAD Map 3D 2015 to service pack3. Since then I cannot open my Industry Model in AutoCAD, it says I don't have the same versions.
So I decieded to update my Industry Model also, but I couldn't, because Industry Model Setup says it's the newest version.
Is there anyone who knows how to update it? Or should I uninstall the SP3?
Many Thanks,
Emese
2 REPLIES 2
first thing which comes to my mind - have you installed all SPs? There is one for Map and another one for Map-Admin and probably one for AIMS as well,
Rob
scheel
when you install the SP3 for AutoCAD Map 2015, then Map is checking the database of the industry model if it has the right Version for SP3.
Thats is the reason you have first to install the SP3 also for Infrastructure Administrator 2015.
After that it is very important that you update the database using the Industry Model Setup 2015.
But be carefull. After you have update the database no lower Version has access to that database.
Thorsten
Thorsten Scheel
Contelos GmbH
