where I can download the map autocad 2011 in Spanish?
Solved by philip.s. Go to Solution.
Hello Alfonso!
If the product is not showing up in your Autodesk Account and as the Autodesk Virtual Agent is currently English only, I have provided the following link for your convenience.
AutoCAD Map 3D 2011 Spanish | 32 BIT | PART 1 , PART 2
AutoCAD Map 3D 2011 Spanish | 64 BIT | PART 1 , PART 2
Should anyone else have a similar request, please contact our Customer Support team via the http://knowledge.autodesk.com/contactus options.
Philip,
Thank you very much for the prompt response.
Muchas gracias por la pronta respuesta, saludos desde México.
