When I assign a coordinate system to the file, Autocad Map crash et close.
I don't know if it is a hardware configuration or I looped something.
I have a Dell PC i7 - Win 10.
Solved by ennine. Go to Solution.
Hi @ennine,
That's not normal behavior. How are you assigning the coordinate system? MAPCSASSIGN? What coordinate system?
Does this happen on all drawings, or just one? Does it happen with an Out-Of-The-Box new template?
Dave
Dave Stoll
Las Vegas, Nevada
Thank you Pointdump for your reply.
- Autocad works whithout problem, but when I swich to Autocad Map and call the cs menu both : shortcut "mapcsassign" or from the Autocad Map tabs, and enter the cs = 32632 at that time Autocad Map crashes and closes.
- I will try to verify this for existing georeferenced drawings.
- I use the default template of Autocad
I have installed Autocad Map 2022 and I discover that it works perfectly.
It seems there is an incompatability with the previous Map releases.
