Hi all,
I'm having an issue dimensioning in AutoCAD. Every time I create a dimension it is offset from the intended location. This only has happened in one particular drawing, and I have tried rebooting the program multiple times. Any insight is appreciated.
Jerry
Although I have not found a solution for dimensioning in Model Space, the dimensions display correctly when made in the viewport in paper space. I will do it this way for the time being.
Jerry,
The only thing I've seen that's close to your problem is the <<<Grip Issue>>> in 2018.
Dave
Dave Stoll
Las Vegas, Nevada
Any chance to get the dwg-file, as it is drawing dependent that would be the most efficient way to get an answer.
Also please let us know which version of AutoCAD Map 3D you are using (screenshot of command _ABOUT would be great).
- alfred -
