I keep getting this error when using the insert command.
I tried to follow this https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Runnin... but it did not fix it.
I tried to reinstall AutoCAD but it didn't fix it.
This is the details
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.InvalidOperationException: Operation is not valid due to the current state of the object.
at Autodesk.AutoCAD.Windows.PaletteSet.Activate(Int32 index)
at Autodesk.AutoCAD.Windows.BlockStream.BlockStreamPaletteTabsHost.refreshAllMultipleModeViews()
at Autodesk.AutoCAD.Windows.BlockStream.BlockStreamPaletteTabsHost.showPaletteTabs(Boolean expand)
at Autodesk.AutoCAD.Ribbon.Commands.BlockStream()
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4150.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
Assembly Version: 24.0.0.0
Win32 Version: 24.0.47.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Acdbmgd.DLL
AdApplicationFrame
Assembly Version: 0.0.0.0
Win32 Version: 3.0.2.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/AdApplicationFrame.DLL
adui24
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/adui24.DLL
AdUiPalettes
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/AdUiPalettes.DLL
System
Win32 Version: 4.8.4001.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
WindowsBase
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Core
Win32 Version: 4.8.4121.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
PresentationCore
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
PresentationFramework
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
System.Xaml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Configuration
Win32 Version: 4.8.3752.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
AdUIMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/AdUIMgd.DLL
AdWindows
Assembly Version: 3.0.2.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/AdWindows.DLL
WindowsFormsIntegration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
PresentationFramework.Aero2
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll
accoremgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/accoremgd.DLL
Acmgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Acmgd.DLL
AcWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/AcWindows.DLL
AcWindows.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AcWindows.resources.DLL
AcCui
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/AcCui.DLL
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
PresentationFramework-SystemXml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
AcMapRibbon
Assembly Version: 24.0.30.14
Win32 Version: 24.0.30.14
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/AcMapRibbon.dll
PresentationUI
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
System.Windows.Forms
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationFramework-SystemXmlLinq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
AcMr
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/AcMr.DLL
System.Runtime.Serialization
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
AcAeNet.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AcAeNet.resources.DLL
AcCloudRender.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AcCloudRender.resources.DLL
AcCustomize.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AcCustomize.resources.DLL
AcDxWizard.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AcDxWizard.resources.DLL
AcExportLayoutUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AcExportLayoutUI.resources.DLL
AcInterfere.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AcInterfere.resources.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AcLayer.resources.DLL
AcLayerTools.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AcLayerTools.resources.DLL
AcMrUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AcMrUi.resources.DLL
AcMultiLineUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AcMultiLineUi.resources.DLL
AcRecoverAll.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AcRecoverAll.resources.DLL
AcScaleList.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AcScaleList.resources.DLL
AcSeamless.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AcSeamless.resources.DLL
AcUnderlay.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AcUnderlay.resources.DLL
AcViewTransitionsUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AcViewTransitionsUi.resources.DLL
AdskConnectionPointMgd.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AdskConnectionPointMgd.resources.DLL
AcCalcUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AcCalcUi.resources.DLL
AcMr.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/en-US/AcMr.resources.DLL
AcMapHiPPIUtility
Win32 Version: 3.4.72.0
CodeBase: file:///c:/program%20files/autodesk/autocad%202021/map/bin/gisplatform/AcMapHiPPIUtility.dll
AcMapResourceManagement
CodeBase: file:///c:/program%20files/autodesk/autocad%202021/map/AcMapResourceManagement.dll
AcMapLoader
CodeBase: file:///c:/program%20files/autodesk/autocad%202021/map/acmaploader.arx
ConvertText
CodeBase: file:///C:/program%20files/autodesk/autocad%202021/map/ConvertText.dll
MapPublishImp
CodeBase: file:///C:/program%20files/autodesk/autocad%202021/map/MapPublishImp.DLL
OSGeo.MapGuide.PlatformBase
Assembly Version: 3.4.72.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/GisPlatform/OSGeo.MapGuide.PlatformBase.dll
OSGeo.MapGuide.Foundation
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/GisPlatform/OSGeo.MapGuide.Foundation.DLL
Autodesk.Map.Platform
CodeBase: file:///C:/program%20files/autodesk/autocad%202021/map/Autodesk.Map.Platform.DLL
Autodesk.MapGuide.Studio.Site
CodeBase: file:///C:/program%20files/autodesk/autocad%202021/map/Autodesk.MapGuide.Studio.Site.DLL
AcMapFeatureEntityTooltipsManager
CodeBase: file:///C:/program%20files/autodesk/autocad%202021/map/AcMapFeatureEntityTooltipsManager.dll
AcMapPaletteTheme
CodeBase: file:///c:/program%20files/autodesk/autocad%202021/map/AcMapPaletteTheme.dll
AcMapThemeFactory
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/AcMapThemeFactory.dll
ResourceManagerRdfImp
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/ResourceManagerRdfImp.dll
System.Data
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Numerics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
AcWorkspaceSelector
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/AcWorkspaceSelector.dll
Autodesk.Map.IM.FeatureSearch
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.FeatureSearch.dll
Autodesk.Map.IM.Genuine
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.Genuine.DLL
Autodesk.Map.IM.Forms
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.Forms.DLL
Autodesk.Map.IM.Map
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.Map.DLL
Autodesk.Map.IM.PlugInHandler
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.PlugInHandler.DLL
Autodesk.Map.IM.ImageResources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.ImageResources.dll
Autodesk.Map.IM.Loader
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.Loader.dll
log4net
Assembly Version: 1.2.13.0
Win32 Version: 1.2.13.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/log4net.DLL
Autodesk.Map.IM.Config
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.Config.DLL
Autodesk.Map.IM.Logging
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.Logging.DLL
Autodesk.Map.IM.ExceptionDialog
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.ExceptionDialog.DLL
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.Exception.DLL
Autodesk.Map.IM.Services
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.Services.DLL
Autodesk.Map.IM.Collections
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.Collections.DLL
Autodesk.Map.IM.FeatureServiceListener
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.FeatureServiceListener.DLL
Autodesk.Map.IM.Tools
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.Tools.DLL
OSGeo.MapGuide.Geometry
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/GisPlatform/OSGeo.MapGuide.Geometry.dll
ManagedInternal
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/ManagedInternal.dll
Autodesk.Map.IM.GwsInterface
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.GwsInterface.DLL
ManagedMapApi
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/ManagedMapApi.dll
Autodesk.Map.IM.Display.GraphicsGeneration
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.Display.GraphicsGeneration.DLL
Autodesk.Map.IM.Display.Settings
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.Display.Settings.DLL
Autodesk.Map.IM.Display.DisplayModelManagement
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.Display.DisplayModelManagement.DLL
Autodesk.Map.IM
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.DLL
Autodesk.Map.IM.Data
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.Data.DLL
Autodesk.Map.IM.Graphic
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.Graphic.DLL
Autodesk.Map.IM.CoordinateSystem.API
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.CoordinateSystem.API.DLL
Autodesk.Map.IM.Data.UnitSupport
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.Data.UnitSupport.DLL
Autodesk.Map.IM.CIP.Waypoints
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.CIP.Waypoints.DLL
Autodesk.Map.IM.CoordinateSystem.Factory
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.CoordinateSystem.Factory.DLL
AcMapThemeUtilMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/AcMapThemeUtilMgd.dll
Autodesk.IDM.Embedded
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.IDM.Embedded.DLL
Autodesk.Map.IM.CoordinateSystem.SpatialReferenceApi
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.CoordinateSystem.SpatialReferenceApi.DLL
Autodesk.IDM.AutoCADEmbedded
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.IDM.AutoCADEmbedded.DLL
Autodesk.Map.IM.MapToAcad.UI
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.MapToAcad.UI.dll
Autodesk.Map.IM.RibbonItems
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.RibbonItems.dll
AcCloudAccess
Assembly Version: 23.1.0.0
Win32 Version: 23.1.0.0
CodeBase: file:///C:/Users/Souk.Nomichith/AppData/Roaming/Autodesk/ApplicationPlugins/Autodesk%20Save%20to%20Web%20and%20Mobile.bundle/Contents/AutoCAD/Win64/AcCloudAccess.dll
AcCloudAccess.resources
CodeBase: file:///C:/Users/Souk.Nomichith/AppData/Roaming/Autodesk/ApplicationPlugins/Autodesk%20Save%20to%20Web%20and%20Mobile.bundle/Contents/AutoCAD/Win64/en-US/AcCloudAccess.resources.DLL
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
FeaturedAppsPlugin
CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/ApplicationPlugins/Autodesk%20FeaturedApps%202020-2021.bundle/Contents/Windows/2021/Win64/FeaturedAppsPlugin.dll
PresentationFramework-SystemData
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll
PresentationFramework-SystemCore
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
Anonymously Hosted DynamicMethods Assembly
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
UIAutomationTypes
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
UIAutomationProvider
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
ContextualTabSelectorRules
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/AcWindows.dll
Autodesk.Map.IM.ContextualTabHelper
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/bin/Autodesk.Map.IM.ContextualTabHelper.dll
AcMapRibbonWrapper
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/AcMapRibbonWrapper.dll
Microsoft.Expression.Interactions
Assembly Version: 4.5.0.0
Win32 Version: 3.0.40218.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Microsoft.Expression.Interactions.DLL
AcLivePreviewContext
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Net.Http
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll
AcCustomize
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/AcCustomize.DLL
AcLayer
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/AcLayer.DLL
PresentationFramework.Luna
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
AcMrUi
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/AcMrUI.DLL
FeaturedAppsPlugin.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/ApplicationPlugins/Autodesk%20FeaturedApps%202020-2021.bundle/Contents/Windows/2021/Win64/en-US/FeaturedAppsPlugin.resources.DLL
Windows.UI
Assembly Version: 255.255.255.255
Win32 Version: 10.0.10011.16384
CodeBase: file:///C:/WINDOWS/system32/WinMetadata/Windows.UI.winmd
System.Runtime.InteropServices.WindowsRuntime
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.InteropServices.WindowsRuntime/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.InteropServices.WindowsRuntime.dll
System.Web.Extensions
Win32 Version: 4.8.4075.0
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Extensions/v4.0_4.0.0.0__31bf3856ad364e35/System.Web.Extensions.dll
System.Web
Win32 Version: 4.8.4075.0 built by: NET48REL1LAST
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
Autodesk.Gis.Map.Shared
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/Autodesk.Gis.Map.Shared.dll
Autodesk.Gis.Map.ManagedADP
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/Autodesk.Gis.Map.ManagedADP.DLL
Autodesk.Gis.ObjectModels.LayerDefinition-2.4.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202021/Map/Autodesk.Gis.ObjectModels.LayerDefinition-2.4.0.DLL
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
Hello @souk.nomichith,
Thank you for posting & providing this information.
A Just-In-Time debugging is a feature that launches Visual Studio debugger automatically, when a program is running outside Visual Studio it encounters a fatal error.
Microsoft offers a solution to resolve this issue on Answers.microsoft.com.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Thanks for responding. I have disabled JIT Debugging in the Internet Options as directed in the link you sent me. I don't have Visual Studio. I still get the same error.
I have also tried the solution suggested and it did not solve the problem
If Visual Studio is not installed, disable script debugging in Microsoft Internet Explorer and check if the pop-up is eliminated. Please conduct the following steps:
4. Then try the insert command again
Related Article: Application does not support just-in-time (JIT) debugging"
Natasha
Helpful Links:
It absolutely did not work. Thanks for responding.
I have re-routed the "I" command shortcut in acad.pgp to refer to "CLASSICINSERT" command instead of the 2021 version of the INSERT command. Its a temporary fix but the new "INSERT" command and JIT Debugging is still a problem.
BTW, I am running AutoCAD 2021, not AutoCAD 2021 Map3D. I get this error with "insert" and "blockspalette" commands. My work around for now is to insert blocks through the design center, but I would like to resolve this, as I have lost some other new features in the AutoCAD 2021 that I liked.
This first started for me when I opened AutocAD first, then tried to open a drawing through file/open command. That seemed to corrupt my profile and create this trouble for me.
I too, have tried to uninstall and re-install AutoCAD, as well as reset to default, and created a totally new profile. All with no solution, still getting the same error.
Previously I had been double clicking the .DWG file to open AutoCAD, which is what I typically do.
@Jeffr-here From my experience design center is slow and it makes AutoCAD slow because it generates some design center files inside the folder which the dwg resides. What I do is open the cad file and drag the blocks into the palette. This way design center doesn't load the entire library of the block's thumbnail. Try it, I hope it helps.
Also as I have mentioned in my previous post as a work around. Re-map the "I" command to "CLASSICINSERT" command.
I can no longer access the blocks palette, I get the error described above when I try to.
I don't think you're addressing the source problem within Autocad. Is JIT debugging what is actually causing the unhandled exception within Autocad? If not, then the inquiry concerns the unhandled exception, not how to disable JIT debugging. There's still the unhandled exception problem that needs to be solved.
Same here. Suddenly happened. All Windows 10 and graphics drivers updated, debugging features unchecked, no visual studio installed, Insert and Blockspalette cause unhandled exception. I can continue but next time I inovke any of them, AutoCAD 2021 crashes. Hope someone can help.
Best regards.
I know this is definately not the best workaround, but I decided to roll back to the 2020 version and the issue is gone. That makes me think this issue is related directly to AutoCAD and not to VS or Windows.
Hope it helps.
