Announcements
Aufgabenfenster / Display Management: some context menus inactive
Peter2_1
Peter2_1
Sometimes it happens on some object classes (see image: label for manholes) that some commands in the context menu are inactive - e.g. "Quickinfo" and "Filter data". Other labels are OK.
After restart the menus are active and OK again.
Where does / could it come from?
AutoCAD Map 3D 2023 German / Oracle
Alfred.NESWADBA
is this a geometric layer? Would you mind uploading the datasource you have used here?
Also please share a screenshot of command _ABOUT so we can see the version+update of AutoCAD and Map3D you are using.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Peter2_1
Hi Alfred
sorry - missed your answer for a small time.
The data is from "wastewater", IM. It happens on layers for labels and on layers for lines.
My "About.dialogue" is here:
