Applications for Object Data
АлексЮстасу
Advisor Advisor
Message 1 of 93
АлексЮстасу
I suggest to collect free programs for Object Data.
And to discuss them.
For example, Autodesk, Copy object data from one object to a set of other objects - COPY_OD.LSP.
Contained in C:\Program Files\Autodesk\AutoCAD...\Sample
Autodesk (?), XD to OD conversions - XD2OD.lsp.
For example, braudpat published lisp to select objects by OD values - Sel_by_OD.lsp.
https://forums.autodesk.com/t5/autocad-map-3d-forum/object-data-how-to-use-the-find-command/m-
p/5445541#M43818
For example, CADaSchtroumpf published lisp for conversion from OD to XD - OD2XD.lsp.
https://forums.autodesk.com/t5/autocad-map-3d-forum/map-3d-od-to-autocad-dwg/m-p/9329382#M56358
In the text of this lisp you must specify the author and his data for the link.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Replies (92)
Message 81 of 93
АлексЮстасу
I almost immediately published the previous new commands (from CADaSchtroumpf) on my website in Additionally.
Now there are three more commands for OD:
From Michiel.Valcke, OD_COPY_MHV, OD_DELETE_MHV - https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/help-needed-map-civil-3d-object-data...
From CADaSchtroumpf, ALL_copy_OD - https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/help-needed-map-civil-3d-object-data...
In OD_DELETE_MHV there was a mistake therefore it is better for OD_COPY_MHV.lsp to take from the enclosed file. Or on the website.
Message 82 of 93
braudpat
SORRY Bad message from Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 83 of 93
АлексЮстасу
Thank you!
In principle:
- One general command with options would be better.
- It would be better not to link OD selection with graphical properties - these are heterogeneous, i.e. potentially independent information...
But I haven't looked closely yet...
There are two more new programs from CADaSchtroumpf on the forum recently:
Point&[email protected] - creating points on polyline vertices with OD "PT_AT_VERTEX",
OD2Label_Pt.lsp - creating MTexts from the values of this OD. For example, vertex numbers.
Message 84 of 93
CADaSchtroumpf has updated/improved its Point&[email protected] and OD2Label_Pt.lsp - for vertices and points.
I also updated their description and downloading on the website.
And
CADaSchtroumpf also created Ptorblk&[email protected] - similar to Point&[email protected], but on vertices can create not only points, but also Map 3D blocks - Map_Survey_Point. Immediately with the corresponding values of their attributes.
Bravo, CADaSchtroumpf!
Message 85 of 93
The code of a routine to convert OdTables to PropertySets appeared. To transfer users descriptive non-graphic data from OD to Civil, Architecture, MEP.
This seems to be a .Net.
Message 86 of 93
Two very simple but useful routines from mmitchellH6TRW, https://forums.autodesk.com/t5/autocad-map-3d-developer/select-all-object-that-have-object-data/m-p/...:
1. SDO - find all objects with Object Data,
2. SDOC - find all objects without Object Data. (I gave the name)
Those who know about our ODEDIT know about similar two commands:
1. ODEDIT_HAS_OD,
2. ODEDIT_HAS_NO_OD.
SDO and SDOC differ in that they do not use user selection of objects, and do not ignore objects on locked, frozen, and disabled layers.
Message 87 of 93
braudpat
Hello @АлексЮстасу
Exactly the same routine into ONE routine from CADaSchtroump - Thanks Bruno !
The routine "ODYesNo" which selects entities from your selection (not ALL the DWG) WITH or WITHOUT ODs
The Health, Bye, Patrice (The Old French EE Froggy)
Patrice BRAUD
Message 88 of 93
braudpat
Hello
A new version of the beautiful Routine  "Sel_By_OD"  from CADaSchtroumpf / Bruno / Bonuscad
I have removed the OLD versions ...
The NEW v2.02 has the bug on String OD field with the Test "DIFFERENT" corrected !
Many THANKS to @CADaSchtroumpf
Patrice BRAUD
Message 89 of 93
braudpat
Hello @АлексЮстасу
An other beautiful routine "OD&PROP2CSV" from CADaSchtroumpf / Bruno / Bonuscad !
Which exports to .CSV Properties and OD values ...
Bye, Pat
Patrice BRAUD
Message 90 of 93
braudpat
Hello @АлексЮстасу
A routine "OD_Incr_Numeric_" for ODs which increments a numeric OD Field ...
NO Error management so you must select ONLY :
-- Objects on unlocked layers
-- Objects with the RIGHT OD Table AND the RIGHT OD numeric Field
Bye, Pat
Patrice BRAUD
Message 91 of 93
BriamR
Hi @АлексЮстасу
I share this AutoLISP script that allows you to change the type of a specific field in an Object Data (OD) table, transforming it between “integer” and “character”. It automatically creates a new table with the modified field, migrates the data from the original table, deletes the old table and renames the new table to the original name. It is an effective lisp to maintain data integrity when updating field types without losing information. for use OD_TypeField
Credits and help for its creation to @O_Eckmann
Message 92 of 93
braudpat
Hello
An other useful routine "OD__ANGLEDEGRE" for Blocks before running MAPEXPORT ...
The Rotation is always in RADIANS so it is not comfortable with other GIS Software
So this routine will fill a Numeric OD Field with the ROTATION in DEGRES !
(princ "\n------ ATTENTION : ZERO Error Management - Objects ON Unlocked Layers ")
(princ "\n------ Select Objects WITH The RIGHT Table OD AND Field OD ")
(princ "\n------ Please RUN into the Model Space and into the WCS \n")
Bye, Pat
Patrice BRAUD
Message 93 of 93
franc_as
By the way....I need more a lisp routine, to purge all unused OD tables from the list..... You know, after objects deletion, their OD tables remains on the list...
any Ideas?
