- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am having this exact problem as described here: Transforming-the-Coordinate-System-of-a-Drawing-does-not-work-and-an-error-message-appears, but I don't understand the solution that is proposed at the end of the article.
Can someone enlighten me please? I have been searching internet for solution for days now and I can't get my head around it.
I am using
. The task is to transform a .dwg file from DenmarkS34-S to ETRS89.UTM-32N (sometimes also the other way around and I run into the same problem). Here's what I do:
- open drawing A which needs to be transformed, and assign coordinate system to it (DenmarkS34-S), then save and close it.
- open a new file B (which is empty), assign a coordinate system to it (ETRS89.UTM-32N), then save.
- still in drawing B I go to Map Explorer tab on Map Task Pane and attach drawing A
- I define a query: location condition Boundary Type "All"
- query mode: Draw
- execute query
- Then I get a long error log: Can't transform point to Lat Long. Can't transform object. LWPOLYLINE - handle 6808. LINE - handle 6566. DIMENSION - handle 67E7 ...etc etc
I eventually got someone to do the transformation for me in MicroStation, but I am determined to find out where I am making a mistake here...
I have attached the dwg file, if someone feels like looking into it.
Thanks in advance!
