AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Annotation Template
10 REPLIES 10
Message 1 of 11
779 Views, 10 Replies
Annotation Template
I need to write an annotation template of a field comprised of 10 digits.  How would I go about writing it just using that last five digits? Any help would be greatly appreciate it!!!
Thanks a million!
10 REPLIES 10
Message 2 of 11
Murph_Map
Look at the substr function.
Example  (substr :Field@ODtables 6)
Murph
Supporting the troops daily.
Message 3 of 11
in reply to: Murph_Map
I will! Thank you, Murph.
Message 4 of 11
 I have tried but no success. The field looks like this: APINUM@well225b. Is this how I should write the function: SUBSTR: (APINUM@WELLB, -5, 5) ? The field is 10 digits long.   Thanks!
Message 5 of 11
Murph_Map
Try (substr :apinnum@wellb 6)
Sent from the Samsung Galaxy Rugby Pro, an AT&T LTE smartphone
Murph
Message 6 of 11
kajar
Murph, can you also tell me how to annotation expression looks like when I want to use operators like / or * in expressions.
I want that text height is coming from object data numeric field and I need formula to divide value or multiply it. I tried (:od_field@ann_template)/2 or *2 not working also tried without parentheses.
Message 7 of 11
Murph_Map
in reply to: kajar
The value  in the OD may be a number but is it a integer or real?  Look at the field in the OD definition and see if its a CHARACTER or REAL or INTEGER. If it's a character you need to use ATOF or ATOI to convert the "string" to a number that can be divided or mulitplied.
Look at the help topics  Functions Reference (AutoLISP).
Murph
Message 8 of 11
kajar
Data type is REAL. I cant get this working. How corect expression must looks like when lets see I want to divide object data real number data field(od_field).
Which variant is correct:
  1. (:od_field@od_table)/2
  2. :od_field@od_table/2
  3. (:od_field@od_table/2)
Message 9 of 11
Alfred.NESWADBA
in reply to: kajar
Hi kajar,
as you see in your post there are a lot of smileys as characters used in your text like  this ( and that :  results in that smiley  (:
You have the option to use the "Insert Code" button (in the top line of that rich text editor with this icon:  {i}   and all within that part will not be converted to smileys.
At least it's like LISP is working and the formulas for division is like that:
( / 4 2) 'which means 4/2
Look to more details >>>here<<<.
-.alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 10 of 11
Murph_Map
in reply to: kajar
here is one example of divisions.
( / :LENGTH_MI@strts_clarksville 2 )
This divides the value of Length_mi in the OD table strts_Clarksville by 2 .
Murph
Message 11 of 11
kajar
Thanks a lot!
I get it working, there was one missing space after /.
