align objects in a straight row
Message 1 of 8
I have a row of individual squares that I am trying to put in a strait line so it pretty much looks as straight as a linear array. I've tried 'ALIGN' but seems to work only on lining up objects for merging together. what command can I use to do this? I tried the ALIGNIT .LISP file, but it doesn't seem to work on map 3D 2017. any other tools available?
Replies (7)
Message 2 of 8
Pointdump
D,
Are we talking Map Features or AutoCAD objects?
If you're talking about AutoCAD objects, one way is to select 'em all and change the "X" value in properties.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 8
Pointdump
D,
Oh, and then there's the CHANGE command. Lynn Allen shows how here:
https://www.youtube.com/watch?v=5HpUAU2vXdc&feature=youtu.be
Dave
Dave Stoll
Las Vegas, Nevada
Message 4 of 8
antoniovinci
Hi Dave,
I fear none of your 2 tips will fit to the OP request.
I'm not aware of a way that line could "attract" the rectangles as a magnet...
Message 5 of 8
parkr4st
dmayjr
are you still trying to park those trailers?
Dave
Message 6 of 8
АлексЮстасу
To try to use parametrization?
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 7 of 8
parkr4st,
Ha! it's a never ending struggle. We got the map created and are able to use it in our GPS tracking tool, now its just a matter of making it prettier. It turns out that the ALIGHNIT LISP file actually works. My objects had to be blocks for it to function properly here's where the LISP file can be found:
http://cadtips.cadalyst.com/2d-operations/align-entities-alignitlsp
the solution was provided on this forum here:
http://forums.autodesk.com/t5/drafting-techniques/align-objects-in-a-straight-line/m-p/6478402/highl...
Message 8 of 8
АлексЮстасу
Um... If boxes - blocks, and the basic line vertical, then is possible without programs - to select all boxes, and to set them identical X from the basic line.
