additions for Object Data
АлексЮстасу
Advisor Advisor
Message 1 of 119
АлексЮстасу
As a task manager, I created for myself such additions for Object Data:
 - OD management
    - Copy definitions from file
    - usage stats
    - Rename columns
    - Reorder fields
    - Update definitions
    - Batch update definitions
    - Remove unused
 - Search OD
    - Find entities with no OD
    - Find entities with OD
    - Find entities with duplicate OD
    - Find entities with multiple OD
    - Find entities with no specific OD
    - Find entities with specific OD
    - Find entities with specific OD values
 - Attach/Detach OD
    - Attach/detach
    - Detach all
    - Detach specified
    - Detach duplicate
 - Copy OD
    - Copy OD from reference
    - Copy values from reference
    - Copy properties/OD from reference
    - Copy properties/OD values from reference
 - Set/edit OD values
    - Set values from XYZ
    - Set values from geometric properties
    - Set values from text
    - Create IDs
    - Replace values
    - Values from field in field
 - Modify entities
    - Convert to 2D polylines
    - Convert to 3D polylines
    - Break
 - Import /export
    - Export to mif/mid
    - Batch  export to mif/mid
    - Export to csv
    - Import from csv
 - - OD table
A small example recently posted on the forum: statistics about OD, viewing OD in the table, finding elements without the specified OD, attaching these elements to the required OD.
This list corresponds to the wishes and ideas from this forum: MAP New features - 01 - Improvments on Object Data, http://forums.autodesk.com/t5/autocad-map-3d-general/object-data-how-to-use-the-find-command/td-p/54... etc.
But the list is longer. The necessity of these possibilities is confirmed by daily use - they greatly accelerate, simplify and improve the work.
What other advanced features of working with Object Data may be needed?
For example, add a drawing with the Object Data on the sample of the specified existing object.  Import/export in kml/kmz, geojson. What else?
The resulting plugin could be a prototype for Autodesk add-ons for Object Data.
We could gather such additions to the forum participants, and offer as a general idea from many experienced users.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Replies (118)
Message 21 of 119
Versions for 2017, 2018:
ODEDIT_2017
64-bit version - https://yadi.sk/d/SPqMB2Qv3TH9EW
ODEDIT_2018
64-bit version - https://yadi.sk/d/JKscnc3r3THVqG
This version of 2018 is better than in the previous post.
Message 22 of 119
I have long been trying to publish ODEDIT in the Autodesk App Store.
Yesterday they wrote to me:
"...Autodesk App Store does not support Map 3D...
Also we will be removing our product name “Map/Civil 3D” from the app name...
And further:
"Civil 3D 2015 – 2018 versions supports only Win 64 bit operating systems.
Hence could you to change the OS to ‘Win64 only’?".
With the fact that Map 3D 2015-2016 supports Win 32 bit.
Discrimination in Autodesk App Store Map 3D applications?
Message 23 of 119
Next iteration. 🙂
Fixed bug in Set values from text, ODEDIT_SETTEXT command. Added an Tolerance to search for items relative to texts. The ability to load the contents of MText into OD values is added.
Added Copy values from reference, ODEDIT_COPY_VALUE command - copying only field values from the OD of the sample object in OD specified graphic elements. The OD itself is not copied.
Added Add values from OD to OD, ODEDIT_ADDVAL_OD2OD command - adding values from one OD field to the field of another OD. The command is executed for graphic elements to which different ODs are simultaneously attached.
Total, now in the demo version of ODEDIT already 30 commands.
odedit_demo_OD_2011-12_32b.arx - https://yadi.sk/d/TR9NYQnS3VMcyR
odedit_demo_OD_2011-12_64b.arx - https://yadi.sk/d/WG-9rJUR3VMd25
odedit_demo_OD_2013-14_32b.arx - https://yadi.sk/d/-NN2IPmp3VMd38
odedit_demo_OD_2013-14_64b.arx - https://yadi.sk/d/HlXpIcZg3VMd4d
odedit_demo_OD_2015-16_32b.arx - https://yadi.sk/d/xoE5tXvQ3VMd5J
odedit_demo_OD_2015-16_64b.arx - https://yadi.sk/d/YTwJA20R3VMd6D
odedit_demo_OD_2017_64b.arx - https://yadi.sk/d/uHXwaJTF3VMd7n
odedit_demo_OD_2018_64b.arx - https://yadi.sk/d/u6hogC7v3VMd8y
ODEDIT_description_en_124d.htm - https://yadi.sk/d/-coLQZwA3VMcuy
ODEDIT_description_en_124d.pdf - https://yadi.sk/i/bFB28HtV3VMcws
Message 24 of 119
In Autodesk App Store, finally, ODEDIT  appeared. Smiley Happy
In my opinion, the signs of Map 3D discrimination are present:
1. ODEDIT could be attributed only to Civil 3D.
2. It was impossible to declare the 32-bit version for 2015-2016, because they are not supported by Civil 3D ...
Still it was impossible to do without the installer in the App Store. Although, in my opinion, enough arx.
It's good that the archive with arx in the App Store is preserved all. After running msi, everything from the archive will appear in C:\ProgramData\Autodesk\ApplicationPlugins\Alexander Sharov ODEDIT for Object Data.bundle\Contents\. In this folder you can take arx for 2011-2016 and for 32-bit.
But you can take directly from my previous message - the version in the App Store fully corresponds to it. Smiley Happy
Message 25 of 119
noambbb
Unable to load odedit_demo_OD_2017_64b.arx  with _appload in MAP 3D
  1. The ARX file (odedit_demo_OD_2017_64b.arx - https://yadi.sk/d/uHXwaJTF3VMd7n) worked before on my computer and suddenly stopped loading. I get "Unable to load odedit_demo_OD_2017_64b.arx".
  2. I am sure my Autocad version is 64 bit 2017.
  3. I tried different opening the file with another computer (version is 64 bit 2017) and it also did not load.
  4. I tried downloading the original file again.
  5. I tried to repair Autocad.
  6. Other ARX files seem to work on my pc.
Any suggestions will be greatly appreciated.
Noam.
Message 26 of 119
АлексЮстасу
1. Try downloading ODEDIT from the App Store. There is an msi installer created by the App Store. But after running msi, the folder C:\ProgramData\Autodesk\ApplicationPlugins\Alexander Sharov ODEDIT for Object Data.bundle\Contents\ appears, in which all arx 2011-2018, 32b, 64b and the program description.
2. Wait 1-1.5 weeks - we are preparing a new version of ODEDIT with fixes and additions.
What features of ODEDIT do you need more?
Message 27 of 119
noambbb
I installed the msi download, the program appears in the plugins,
when I press it I get "odedit unknown command".
Message 28 of 119
АлексЮстасу
I'll try to understand what the problem is.
Message 29 of 119
noambbb
OD table is the most used, after that create IDs.
Message 30 of 119
АлексЮстасу
Next version - 125.
Fixed bug in Set values from text, ODEDIT_SETTEXT command for closed polylines.
Added ODEDIT_TRANSLATE command - replace OD names, OD fields names, values in OD fields in the active dwg. Replacements based on user-generated matching-files for OD names, OD fields names, values in OD fields.
The command makes it possible to work with decrypted values, if in the end it is necessary to create code values. For example, the values of the OD "color" field should as codes: 1, 2, ..., 255. Or: FF0014, FFF014, ..., 14FFF0. Etc. But the user can write the color in clear words: "yellow", "red", "blue", etc. And before the end of work, you can replace the clear names with such codes.
Or for foreign customers with a different language (Chinese, Arabic, Swedish, etc.), you can do all the work in OD in your language, and before the completion, translate it into the customer's language.
This is a "secret" command - it is not in the menu. 🙂
Total, now in the demo version of ODEDIT already 31 commands.
odedit_demo_OD_2011-12_32b.arx - https://yadi.sk/d/moYiXYuI3YPDXm
odedit_demo_OD_2011-12_64b.arx - https://yadi.sk/d/ecqp1AER3YPDZH
odedit_demo_OD_2013-14_32b.arx - https://yadi.sk/d/i_OJwtjI3YPDaY
odedit_demo_OD_2013-14_64b.arx - https://yadi.sk/d/GUFpuYuT3YPDbe
odedit_demo_OD_2015-16_32b.arx - https://yadi.sk/d/HwoYOEMY3YPDcz
odedit_demo_OD_2015-16_64b.arx - https://yadi.sk/d/fMiwDHs83YPDfD
odedit_demo_OD_2017_64b.arx - https://yadi.sk/d/xMOGZeWD3YPDhF
odedit_demo_OD_2018_64b.arx - https://yadi.sk/d/3P0e9KHU3YPDiy
ODEDIT_description_en_125d.htm - https://yadi.sk/d/wri8NZ_03YPDmm
ODEDIT_description_en_125d.pdf - https://yadi.sk/i/OikGpu1k3YPDLm
In the App Store, you do not need to download ODEDIT yet - just the old version. I'll let you know after the update.
Message 31 of 119
noambbb
Thanks! this is Wonderful.
Message 32 of 119
JC-OUAKNINE2
Hi Alexander,
I have just replace by the new arx included in your link.
ODEDIT_CTL command works perfectly.
Thanks.
Although your version on APPSTORE is demo-mode,
Can I use it on two PCs (with 2 autorised MAP 2017 and 2 IDs Autodesk), for production on a real project.
For example, I have more than 1000 polylines (45km), and maybe between 10 and 20 fields to manage).
Because solution with .SDF or .SHP (FDO connection) displeased me.
What about copyright and durability of your code, apply to my project case (including services provided by Autodesk Appstore-terms of contract)?
Thanks a lot.
Jean-Christophe OUAKNINE
Message 33 of 119
АлексЮстасу
ODEDIT does not add any of its limitations to either the OD or the model.
1000 polylines with 10-20 fields for characteristics is a bit. According to my impressions OD, even very "heavy", do not reduce the speed of work in AutoCAD.
ODEDIT - free functional demo version. It can be used in any convenient way. Until October-November, I do not plan any significant changes, except for corrections, improvements and, possibly, additions.
Copyright belongs to me. Smiley Happy  But only on the idea of ​​the extensive use of the capabilities of Object Data as a convenient and technological internal database. And to implement this idea - on the plugin ODEDIT itself. But only this.
ODEDIT users have two duties:
1. use or not use,
2. to praise or scold.
Depending on the mood.Smiley Happy
By the way, I've already written many times that it would be better for everyone to have Autodesk do it.
Message 34 of 119
JC-OUAKNINE2
Hi Alexander,
Thanks a lot for your response.
Sure I'll give you feedbacks from practice, to improve your plugin. It looks already excellent.
Have a good day.
Message 35 of 119
АлексЮстасу
Next version - 1.125.1.
ODEDIT_TRANSLATE is added to the menu. ODEDIT_TRANSLATE has the ignoring of spaces before and after the values ​​- from random user errors.
In ODEDIT_REPLACE the possibility of using masks - "*" is added not only for replaceable, but for replacement values. For example, to add characters at the beginning of the values, at the end of the values: "abc *", "* abc", etc.
Made ODEDIT_CALCULATE - calculations in the OD fields. But the forums expressed doubts about the need for such a command. Therefore, this command was not added to the demo version. Smiley Happy
Added ODEDIT_LOAD_ATTRS, ODEDIT_STORE_ATTRS, ODEDIT_ATTR_TEMPLATE - commands for loading attribute contents in OD fields, uploading OD field values ​​to attributes, creating a template file for describing the correspondence of attributes and fields.
ODEDIT_LOAD_ATTRS is more powerful and unambiguous than loading attributes into OD fields using ADEGENLINK. Once created, the attributes/fields correspondence files can be saved and transferred to other users.
Total, now in the demo version of ODEDIT already 34 commands.
odedit_demo_OD_2011-12_32b.arx - https://yadi.sk/d/LSQ0DlHn3Zz8DM
odedit_demo_OD_2011-12_64b.arx - https://yadi.sk/d/p3pIW9HR3Zz8Em
odedit_demo_OD_2013-14_32b.arx - https://yadi.sk/d/nt21Brs13Zz8Fv
odedit_demo_OD_2013-14_64b.arx - https://yadi.sk/d/eEiPIsjm3Zz8C3
odedit_demo_OD_2015-16_32b.arx - https://yadi.sk/d/SRfFxm3Y3Zz8J2
odedit_demo_OD_2015-16_64b.arx - https://yadi.sk/d/RXajRcBv3Zz8Ji
odedit_demo_OD_2017_64b.arx - https://yadi.sk/d/9wvwC1RP3Zz8KP
odedit_demo_OD_2018_64b.arx - https://yadi.sk/d/pMDj85DI3Zz8LL
ODEDIT_description_en_125-1d.htm - https://yadi.sk/d/hvC-HMFU3Zz8Pn
ODEDIT_description_en_125-1d.pdf - https://yadi.sk/i/Cgi-t05u3Zz8NL
In the App Store can be downloaded so far only the previous version - 1.125. I'll let you know after the update.
Message 36 of 119
In the App Store, finally released version 1.125.1 ODEDIT.
Longer than a month ...
In this publication, the links to the video are corrected in the description files.
Message 37 of 119
Next version - 1.125.2.
In Upload to attributes, ODEDIT_STORE_ATTRS - fixed bug uploading numbers values into attributes. And now only attribute names are case sensitive.
Added ExplicationODEDIT_EXPL - command to create a report (explication) of data from the OD with calculations in csv format.
Total, now in the demo version of ODEDIT already 35 commands.
odedit_demo_OD_2011-12_32b.arx - https://yadi.sk/d/kvqjOFHvQX1fdg
odedit_demo_OD_2011-12_64b.arx - https://yadi.sk/d/5Ee2yOVqed_MpQ
odedit_demo_OD_2017_64b.arx - https://yadi.sk/d/DizRLkWA02srBA
odedit_demo_OD_2018_64b.arx - https://yadi.sk/d/tLS7DDJLeMcQGQ
odedit_demo_OD_2019_64b.arx - https://yadi.sk/d/3vJ-uWwqS3yswg
ODEDIT_description_en_125-2d.htm - https://yadi.sk/d/rmrQb9iCeVgW0A
ODEDIT_description_en_125-2d.pdf - https://yadi.sk/i/NFyYrTsEOWRqaA
So far we have the opportunity to give only for 2011-2012 and for 2017-2018.
2019 may not work - if not working, please report it.
Therefore, in the App Store, we have not yet published. And in the App Store you should always wait about a month.
Message 38 of 119
Full set 2011-2019.
2019 fixed. But if it doesn't work either - report right away.
odedit_demo_OD_2013-14_32b.arx - https://yadi.sk/d/IP8pU73FY8eAiA
odedit_demo_OD_2013-14_64b.arx - https://yadi.sk/d/VD9iM3ITxBYnyQ
odedit_demo_OD_2015-16_32b.arx - https://yadi.sk/d/zeOwfIojiNe_eg
odedit_demo_OD_2015-16_64b.arx - https://yadi.sk/d/_hHdSZVLZ3TOsQ
odedit_demo_OD_2019_64b.arx - https://yadi.sk/d/_1A7N-R2zs4KTA
Message 39 of 119
If you can't take ODEDIT from my links on the disc, the version 1.125.2 in the Autodesk App Store:
https://apps.autodesk.com/CIV3D/en/Detail/Index?id=6058493316603791142&appLang=en&os=Win64
Message 40 of 119
noambbb
When I try to load the current arx file I get this message: "Unable to load odedit_trial_OD_2019_64b.arx file."
I also installed the msi file from the appstore but I get  "_ODEDIT_CTL Unknown command "ODEDIT_CTL".
Maybe this has something to do with upgrading to Autocad Map 2019?
