AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
3D Polyline to show linetype
10 REPLIES 10
Message 1 of 11
tamara
6453 Views, 10 Replies
is it possible to show different 3D Polyline linetypes in AutoCAD Map 3D or in plain AutoCAD. I can't get them to show, and it seems a bit odd if this is not possible... Also I can't find anything clear on this subject on net.
10 REPLIES 10
Message 2 of 11
AutiCAD does not display linetypes for 3D polylines.
Of course, it 's weird, but it 's, alas, it is.
You can use linetypes in Map 3D in sdf.
It seems that special linetypes can be used in 3D Civil objects in dwg.
But they will not be visible if you open such dwg in normal AutoCAD.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 3 of 11
TerryDotson
in reply to: tamara
While AutoCAD won't display linetypes on 3DPoly's it can store the designation.  So what I used to do was make all the assignments, then right before plotting:
  1. Save to TRASH.DWG.
  2. QSelect all 3dPolys.
  3. Explode the 3dPolys
  4. Plot
  5. Close
Sad that it was almost 30 years ago and it's still that way.  How much blue theme would you give up for some useful functionality?
Message 4 of 11
O_Eckmann
in reply to: tamara
I've written a plugin to show linetype on 3D poly. I join DLL to load with NETLOAD command
Once it's loaded, you have 2 commands :
LINTYPP3DON to show linetype
LINTYPP3DOFF to show standard AutoCAD display (linetype not shown)
Olivier
Olivier Eckmann
Message 5 of 11
tamara
in reply to: O_Eckmann
Nice,
I am familiar with .Net API for AutoCAD. Could you tell me a bit about your code, it sounds interesting. Didn't occurred to me to follow that approach 😄
Message 6 of 11
O_Eckmann
in reply to: tamara
It's an overrulle on worlddraw to redraw each segment as line instead of drawing 3DPolyline, because line, even in 3D, support graphical linetype.
Olivier
Olivier Eckmann
Message 7 of 11
tamara
Thank you, I will test it nowadays.
Message 8 of 11
Mahass
Very nice plug in ... thanks for you.
I tried, it work perfectly. Can you tell me in which language it is written? if it is a .NET DLL i'll be thankful if you send me the code.
Message 9 of 11
JanardFugro
in reply to: tamara
Enter command LINETYPE3DPLINEON to display line type and command LINETYPE3DPLINEOFF to switch it off
Message 10 of 11
gla_nojaf
Could you please publish or send the code for this plugin, i am unable to load it in my release of autocad and it would be very useful to have.
Message 11 of 11
JanardFugro
in reply to: gla_nojaf
Sorry to hear that, may be this command only works in AutoCAD civil 3D. it's not a plug in.
Technology Administrators
