AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
3D geology map
7 REPLIES 7
Message 1 of 8
1921 Views, 7 Replies
3D geology map
I am new to AutoCad and I have been asked to make a 3D geology map of a pit.  I have the pit design dxf imported in ac3d and want to map on it.  Can I make 3D polylines? Can I draw polylines of geologic features and snap then to elevation contours of the pit design to give them Z dimensions?  Does anyone have any experience making 3D geology maps in ac3d? Any help, tips, or tutorials that would help me out with this would be much appreciated.  Thanks!
-Michelle
7 REPLIES 7
Message 2 of 8
antoniovinci
With Autocad, nothing's impossible, sir.
Unfortunately I don't know what do you mean about "pit", so please upload a couple of screenshots, thanx.
Message 3 of 8
Its an open pit at a mine.  The dxf is basically just a topographic map of a big hole the the ground.  Thanks
Message 4 of 8
alexlibrelon
To boreholes, use the civil 3D - Borehole Import
Alex Librelon
www.alexlibrelon.blogspot.com
www.youtube.com/alexlibrelon
Alex Librelon
Projetista Master - Youtube | Blog | Linkedin
- Marque a resposta que resolveu o seu problema como solução, isso ajuda os outros usuários em suas buscas;
- Clique em "Curtir" caso a resposta tenha ajudado;
Message 5 of 8
istigatore
If the dxf contains the z value you can export as 3d polyline, then make a 3d map...
Message 6 of 8
antoniovinci
in reply to: istigatore
Hai aspettato 7 anni per scrivere 'sta cazzata, Istigato'..?
Sei troppo forte, torna a trovarci !
Message 7 of 8
Did you ever get anywhere with this I am trying to tackle the same problem.
Thank you
Message 8 of 8
parkr4st
Murph explains most of the how to here.             http://map3d.wordpress.com/?s=contour
Technology Administrators
AutoCAD Beta
