Hello there,
I am using Civil 3d 2022 (Map 3d) and getting a 0 objects querry.
I have done this procces previuosly in 2013 and it worked with no issues.
I am attaching a sample dwg where I want to extract atributes from
I also attaching a snapshot of my querry
Does this have anything to do with the "Super User"?
Guillermo
Civil 3d 2022
Solved by Gary_Braun. Go to Solution.
I didn't play around with it enough to get your entire query working, but I changed 2DPOLYLINE to LWPOLYLINE and was able to query in the linework without any of the other query parameters added. I added the AssetID = "" line next and got 0 items when queried, but only because all of the pipe asset IDs were populated. After I deleted the AssetID from one of the mains and re-ran the query it brought that main in. So I don't know how representative this sample is of your entire drawing, but I didn't carry on too much further after that. I think you just need to make sure your query is valid for the objects you are trying to retrieve.
thank you @Gary_Braun
I will follow some of your procedures and be more careful when trying to querry items.
Guillermo
Civil 3d 2022
