AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
vb.net - change button backgroundcolor or dis/enabled StaticPicture
1 REPLY 1
jan_tappenbeck
550 Views, 1 Reply
jan_tappenbeck
hi !
is it possible to Change the button background-Color or dis/enabled a staticpicture by runtime via vb.net?
for background i did not found properties!
for staticpicture! i try
Private WithEvents _Img_ProjCurrent As Autodesk.Map.IM.Forms.PictureBox
Private _ImageProjCurrent As String = "$PICAKTUELL"
 Private Sub Dialog_load(ByVal sender As Object, ByVal e As System.EventArgs) Handles MyBase.Load
 If Me.Dialog.Controls.Contains(_ImageProjCurrent) Then
                _Img_ProjCurrent = CType(Me.Dialog.Controls.ApiItem(_ImageProjCurrent), Autodesk.Map.IM.Forms.PictureBox)
end Sub
here i get the message that the staticimage could not to be convert!
cound someone help?
regards Jan
hi !
end Sub
cound someone help?
regards Jan
1 REPLY 1
jan_tappenbeck
here the right way ....
Private WithEvents _BT_ProjCurrent As Autodesk.Map.IM.Forms.Button
' special color
_BT_ProjCurrent.Desktop.BackColor = Drawing.Color.LightGreen
'default Color
_BT_ProjCurrent.Desktop.BackColor = System.Drawing.SystemColors.Control
' special color
'default Color
