Hi @humbertoha_sae ,
To set TEXTSIZE value, you could use this line
(setvar "TEXTSIZE" 1.0)
But this value is used only if current text style has a height of 0.
If text style has a height other than 0, it's used instead of textsize value.
If you want to know heigth of current text style you can use this command
(cdr (assoc 40 (tblsearch "STYLE" (getvar "TEXTSTYLE"))))
Olivier
Olivier Eckmann
![EESignature EESignature](http://autodesk.i.lithium.com/t5/image/serverpage/image-id/1272565i464DC3DC646B4F11/image-size/original)
