AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
SHP import
5 REPLIES 5
fieldguy
2660 Views, 5 Replies
SHP import
I am looking for some help with SHP import using mapapplication.importer.  I have the dotnet importexport example from map objectarx but the import only supports MAPINFO and MIF formats.
I can import the entities (closed polygons) but having trouble with creating object data table and od records parts.
5 REPLIES 5
norman.yuan
in reply to: fieldguy
@fieldguy wrote:
... map objectarx but the import only supports MAPINFO and MIF formats.
It does support importing shape (how could it not?). You simply pass "SHP" in the importer's Init() method. As for OD data, you add an ImportDataMapping with ImportDataMapping.NewObjectDataOnly/ExistingObjectDataOnly and supply a OD table name when set the datamapping to input layer.
I thought the code sample from MAP objectARX SDK shows all the tricks. But I can put together a simple SHP sample code later, if you wish.
Norman Yuan
Drive CAD With Code
norman.yuan
in reply to: norman.yuan
Below is the code sample of importing SHAPE:
using System.IO;
using Autodesk.AutoCAD.ApplicationServices;
using CadApp = Autodesk.AutoCAD.ApplicationServices.Application;
using Autodesk.Gis.Map;
using Autodesk.Gis.Map.Project;
using Autodesk.Gis.Map.ObjectData;
using Autodesk.Gis.Map.ImportExport;
namespace ImportShp
    public class ShpImportUtil
        private Importer _mapImporter = null;
        private Document _dwg = null;
        private MapApplication _mapApp = null;
        public ShpImportUtil(Document dwg)
            _dwg = dwg;
            _mapApp = HostMapApplicationServices.Application;
        public void ImportShape(string shpFileName, bool attributeAsOdData)
            if (!File.Exists(shpFileName))
                throw new FileNotFoundException(
                    $"Cannot find shape file: \n{shpFileName}");
            _mapImporter = _mapApp.Importer;
            DoImport(shpFileName, attributeAsOdData);
        #region private methods
        private void DoImport(string shpFile, bool addOdData)
            _mapImporter.Init("SHP", shpFile);
            var fileName = Path.GetFileNameWithoutExtension(shpFile);
            foreach (InputLayer inputLayer in _mapImporter)
                // use file name as layer name
                // assume it is qualified to be AutoCAD layer name
                var layerName = fileName;
                inputLayer.SetLayerName(LayerNameType.LayerNameDirect, layerName);
                if (addOdData)
                    // use file name as OD table name
                    // assume the drawing does not have an OD table with the same name
                    var odTableName = fileName;
                    inputLayer.SetDataMapping(ImportDataMapping.NewObjectDataOnly, odTableName);
            _mapImporter.ImportPolygonsAsClosedPolylines = true;
            var result = _mapImporter.Import(true);
            var count = result.EntitiesImported;
            var msg = $"{count} entit{(count > 1 ? "ies" : "y")} imported!";
            CadApp.ShowAlertDialog(msg);
        /// <summary>
        /// Make sure a new OD Table name
        /// </summary>
        /// <param name="tableName"></param>
        /// <returns></returns>
        private string GetValidObjectDataTableName(string tableName)
            ProjectModel proj = _mapApp.Projects.GetProject(_dwg);
            Tables tables = proj.ODTables;
            int i = 0;
            string tName = tableName;
            while (tables.IsTableDefined(tName))
                i++;
                tName = tableName + "_" + i;
            return tName;
        #endregion
As you can see, to let Importer to create OD data from SHAPE's attribute data, you only need to set DataMapping to the InputLayer (for shape, only one layer per shape file).
To use it in a CommandClass:
using Autodesk.AutoCAD.Runtime;
[assembly: CommandClass(typeof(ImportShp.MyCommands))]
namespace ImportShp
    public class MyCommands
        [CommandMethod("ImportShp")]
        public static void RunCommandA()
            var dwg = CadApp.DocumentManager.MdiActiveDocument;
            var ed = dwg.Editor;
            var shpFile = GetShapeFileName();
            try
                var mapUtil = new ShpImportUtil(dwg);
                mapUtil.ImportShape(shpFile, true);
            catch (System.Exception ex)
                ed.WriteMessage("\nError:\n{0}.", ex.Message);
            finally
                Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
        private static string GetShapeFileName()
            var shpFile = "";
            using (var dlg = new System.Windows.Forms.OpenFileDialog())
                dlg.Title = "Select Shape File for Lmport";
                dlg.Multiselect = false;
                dlg.Filter = "Shape File *.shp|*.shp";
                if (dlg.ShowDialog()== System.Windows.Forms.DialogResult.OK)
                    shpFile = dlg.FileName;
            return shpFile;
HTH
Norman Yuan
Drive CAD With Code
fieldguy
Thanks again @norman.yuan. Kudos!
Your code is easy to read.
subash.nalla
Hi can you share me the dotnet example from map objectarx but the import only supports MAPINFO and MIF formats code. I tried numerous ways but was not able to import the Object Data inside the MIF file. Thanks in advance.
norman.yuan
According to your post in the .NET forum, it seems you have already know how to use Autodesk.Gis.Map.ImportExport.Importer xlass to import *.MIF file. You only need to configure the Importer a bit more details: setting up each InputLayer.
By default, if you do nothing about the InputLayer, AutoCAD Map will use the map layer name as AutoCAD layer name and use the Coordinate System of the map, and ignore the attribute data (only import geometries). You can setting up the InputLayer as you needed: using different Coordinate system (Map will automatically does the CS conversion); using desired AutoCAD layer name; and importing attribute data as Object Data. In your case, you need to call InputLayer.SetDataMapping(). The code would be like:
foreach (InputLayer layer in _importer)
     // If needed, change the CS
     layer.TargetCoordinateSystem = layer.OriginalCoordinateSys; // or whatever CS
     // If needed, use desired CAD layer name, other than the default (Map layer name)
     layer.SetLayerName(LayerNameType.LayerNameDirect, "MyDesiredLayerName");
     if ([I need import OD])
        layer.SetDataMapping(ImportDataMapping.NewObjectDataOnly, "[OD Table Name]")
Obviously, the the import source has multiple layers, you want to make sure the layer name/OD table name do not duplicate. Usually, you would simply use the map layer name for both CAD layer name and OD Table name.
Hope this helps.
Norman Yuan
Drive CAD With Code
Technology Administrators
