AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Setup for AutoCAD Map 3d Addin
1 REPLY 1
giskumar
579 Views, 1 Reply
giskumar
Hi All,
Any body help me how to create a setup file for AutoCAD Map 3d (2016) Addin?
After installing that setup it should load that command in AutoCAD automatically.
Thanks & Regards,
Sitaram.
Hi All,
Thanks & Regards,
Sitaram.
1 REPLY 1
norman.yuan
in reply to: giskumar
norman.yuan
What kind of "Add-in" do you refer to? While the traditional approach of "loading on start-up" by using acad.lsp and/or loading per-document of acaddoc.lsp is still one of valid, viable options for add-ins of any type, if you are talking about loading DLLs developed with AutoCAD/Map .NET API, you can easily make the DLL add-in be loaded automatically on demands either by editing Windows registry (you can then build a setup with the *.reg file); or use autoloader, which has been available since Acad2013.
You can search the net for "AutoCAD app autoloading". There are a couple of them:
https://www.autodesk.com/autodesk-university/class/Depth-Look-AutoCAD-App-Autoloader-Module-2013
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-a...
HTH
Norman Yuan
Drive CAD With Code
HTH
Norman Yuan
Drive CAD With Code
