Goal: to modify this expression to round the inverts and lengths using two places. It is currently rounds the info to 0 places before doing the calculations.
ROUND({Start Invert Elevation}-{End Invert Elevation})/ROUND({2D Length - Center to Center})
I picked this expression up from another board by a user named Christopher. I am trying to "fix" the problem caused by the rounding calculations in the pipe labeling. If you calculate the slope of a pipe using 9 places as it is calcuated by C3D, then you come up with the same result. But my label is only to 2 which will give you a slightly different result is calculated.
The above expression works the way I need in that it is rounding the criteria and then does the calculation to come up with the info for the label. The only problem I have is that it is rounding it to a whole number instead of to 2 places before doing the calc.
Is there something I can add to the expression to cause it to use .xx?
Thanks in advace
Wayne
Thanks in advace
Wayne
(ROUND(({Start Invert Elevation}-{End Invert Elevation})*100)/ROUND(({2D Length - Center to Center})*100))/100
The above expression worked. Only change I made was to take off the last /100 and chose the "grade/slope" option under the expression editor and then I displayed the label to two places.
This answer was given to me on the C3D Customization board.
