I'm currently importing shapefiles via C# code into Civil3D with its attributes converted into FDO.
After a few imports, it happens that the file becomes "corrupted", i.e. I'm no longer authorized to import it with Objects Data.
If I remove the line that allows the attributes to be imported, the import works (like a normal Mapimport). The line of code is: "inputLayer.SetDataMapping(ImportDataMapping.NewObjectDataOnly, fileName);"
Here is my code :
[CommandMethod("AEPImportShape")]
public void AEPImportShape()
Stopwatch sw = new Stopwatch();
sw.Start();
MapApplication mapApp = HostMapApplicationServices.Application;
using (Importer importer = mapApp.Importer)
Autodesk.AutoCAD.Windows.OpenFileDialog ofd = new Autodesk.AutoCAD.Windows.OpenFileDialog("Select Shapefile", null,
"shp", "Select shp", Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.AllowAnyExtension);
if (ofd.ShowDialog() == System.Windows.Forms.DialogResult.OK)
//Array.Sort(shpFiles);
string shpFiles = ofd.GetFilenames()[0];
importer.Init("SHP", shpFiles);
string fileName = Path.GetFileNameWithoutExtension(shpFiles).Replace(" ", "");
foreach (InputLayer inputLayer in importer)
inputLayer.SetLayerName(LayerNameType.LayerNameDirect, fileName);
//inputLayer.Dispose();
importer.ImportPolygonsAsClosedPolylines = true;
ImportResults result = importer.Import(true);
sw.Stop();
//importer.Dispose();
dynamic acadApp = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
acadApp.ZoomExtents();
If I copy the shapefile, and retry the import, sometimes it works with the ODs. I repeated this manip several times.
Here is the error:
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
Autodesk.Gis.Map.MapImportExportException: Exception of type 'Autodesk.Gis.Map.MapImportExportException' was thrown.
at Autodesk.Gis.Map.ImportExport.Importer.Init(String formatName, String fileName)
at AEPCreateProfile.MyCommandsAEP.AEPImportShape() in C:\Users\maxime.chavet\Documents\RDC29\VISUAL_STUDIO\Profile\Profile\Class1.cs:line 68
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
Here is my code :
sw.Start();
sw.Stop();
Here is the error:
Solved by fieldguy. Go to Solution.
your code works ok for me, but i don't have much shp data to test. do you have a problem file you can share?
the error msg you posted indicates an error occurred at line 68 in Class1.cs - that does not match the code you posted.
have you tried a try{} catch{} structure to check for MapException?
Thank you for your answer
As I said, it's this line: inputLayer.SetDataMapping(ImportDataMapping.NewObjectDataOnly, fileName); ; when I import the Object Data.
I tried a lot of things to repair these data in QGIS but it still doesn't work. I generated again the entire layer, but it doesn't work. I tried with another point layer and it works.
You can download the data here: https://we.tl/t-KMt8pFRZuV
I got this Exception Thrown :
System.NullReferenceException: 'Object reference not set to an instance of an object.'
the problem is the length of "fname" - it's ok to create a layer name but too long for a table name.
SetLayerName(LayerNameType.LayerNameDirect, fname) // works
SetDataMapping(ImportDataMapping.NewObjectDataOnly, fname) // does not work
if you use OOTB "MapImport", you will see that autocad truncates the table name to 25 chars. QGIS does not.
