Is there no easy way to get the count of records in any given object data table? I would like to inform the user that there are empty tables. Do I have to do something like create an array of booleans?
I have found the sdk example with create table, add, show, delete record but they use tables.getobjectrecords with an objectid. I'd rather not try all of the objects just to determine that the table is empty.
fieldguy,
Easy? very relative... 😉
It appears to me all records for all tables are in the same _location_ thusly I don't think there is an alternative to iterating the records.
Maybe something like this ...
public int do_getRecordCount(string forTableName) { int rtnval = 0; using (DocumentLock docLock = Application.DocumentManager.MdiActiveDocument.LockDocument()) { Tables tables = HostMapApplicationServices.Application.ActiveProject.ODTables; using (Transaction tm = doc.TransactionManager.StartTransaction()) { BlockTable bt = (BlockTable)tm.GetObject(db.BlockTableId, DatabaseServices.OpenMode.ForRead, false); BlockTableRecord btr = (BlockTableRecord)tm.GetObject(bt[BlockTableRecord.ModelSpace], DatabaseServices.OpenMode.ForRead, false); Records rS = tables.GetObjectRecords(0, btr.ObjectId, Autodesk.Gis.Map.Constants.OpenMode.OpenForRead, false); if (rS.Count > 0) { foreach (Record r in rS) { if (r.TableName.ToUpper() == forTableName.ToUpper()) rtnval++; }//foreach Record }//if rS tm.Abort(); //not really necessary in this case }//Transaction }//DocumentLock return rtnval; }
You probably do not have to lock the document but that would depend on what else you are doing. Certainly not necessary for this.
r,
dennis
fieldguy,
r,
dennis
Agreed. I was looking for tables.count or table.count which do not exist. These are odd structures IMO. Why do I have to use gettablenames as a string collection just to get a count of the number of tables?
Your answer works very well. Thanks. I did not realize I could get all the records at once using the blocktablerecord "ModelSpace".
vb code - requires Imports acadapps = Autodesk.AutoCAD.ApplicationServices and
Imports acaddbs = Autodesk.AutoCAD.DatabaseServices
Public Shared Function getodrecordcount(ByRef findtable As String) As Integer
Dim returnval As Integer = 0
Dim doc As acadapps.Document = acadapps.Application.DocumentManager.MdiActiveDocument
Dim db As acaddbs.Database = doc.Database
Dim tables As ObjectData.Tables = HostMapApplicationServices.Application.ActiveProject.ODTables
Using doclock As acadapps.DocumentLock = doc.LockDocument
Using mytx As acaddbs.Transaction = db.TransactionManager.StartTransaction
'Open the Block table for read
Dim acBlkTbl As acaddbs.BlockTable = mytx.GetObject(db.BlockTableId, acaddbs.OpenMode.ForRead)
'Open the Block table record Modelspace for read
Dim acBlkTblRec As acaddbs.BlockTableRecord = mytx.GetObject(acBlkTbl(acaddbs.BlockTableRecord.ModelSpace), _
Dim odrecords As ObjectData.Records = tables.GetObjectRecords(0, acBlkTblRec.ObjectId, Constants.OpenMode.OpenForRead, False)
If odrecords.Count > 0 Then
For Each odrec As ObjectData.Record In odrecords
If odrec.TableName.ToUpper = findtable.ToUpper Then
returnval += 1
Next
mytx.Abort()
End Using 'transaction
End Using 'document lock
Return returnval
End Function
returnval += 1
Next
mytx.Abort()
Return returnval
End Function
