Hi, is there any library that converts Geometry features with arc to polylines with bulges?
Using the GeometryConverter.Autocad Library I only get polylines without bulges.
Just wanted to check before coding my own converter.
Regards
Regards
Solved by dries.ketels. Go to Solution.
For anybody....
the solution:
var feature = //some autocad map feature
var geometry = feature.Geometry;
var converter = new Autodesk.Map.IM.GeometryConverter.AutoCAD.Converter();
var polyLine = converter.ConvertTo(geometry as LineString, typeof(Polyline)) as Polyline;
For anybody....
the solution:
