AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
how to trace multiple connected lines on mouse move to draw new line
1 REPLY 1
giskumar
630 Views, 1 Reply
giskumar
I am having multiple pieces of connected lines available. Now I want to draw a new line (a portion from the connected small lines) exactly on top of connected lines by using mouse. The placement process should follow below steps.
1. click the start point on one of the connected lines
2. Drag the mouse along with the connected lines till you reach the required end point
3. click the end point on one of the connected lines
4. A new line should be drawn from start point to end point by following the mouse trace.
Any existing functionality or C# code will be helpful.
1 REPLY 1
norman.yuan
in reply to: giskumar
norman.yuan
I have an article posted years ago about trace a single polyline with mouse move:
https://drive-cad-with-code.blogspot.com/2014/09/moving-mouse-cursor-to-trace-polyline.html
Sorry for the video clip in the article not working because of modern browser no longer support flash video. But the code is actually rather easy to read/follow for you to get an idea.
Of course, you need to add extra code to extend the tracing drawable for the Transient Graphic for multiple connected curve (polyline, or line) and handle the situation of how they connected: end-to-end, one-cross-the-other, end-to-middle (branch).... The code would get complicated quickly as you can see.
Norman Yuan
Drive CAD With Code
Norman Yuan
Drive CAD With Code
