(Started here: https://forums.autodesk.com/t5/autocad-map-3d-forum/forms-drawing-order-of-staticpicture/td-p/118537...
but continued here ..)
Oracle, Industry Model (but maybe the same in FDO ..)
I want to add two static overlapping images to my forms, and I want to place one image "above" the other - a kind of drawing order.
How can I define the "draw order" of static images?
this works using pictureboxes and their image sources. in some kind of event, you can change the picturebox image source.
i had to try it. it seems a bit cumbersome. my understanding is you can do this but you have to re-order all of the images yourself.
public partial class Form1 : Form
private static Bitmap bmp1 = new Bitmap(@"C:\Users\user\Pictures\Screenshots\Screenshot 2023-03-26 051845.png");
private static Bitmap bmp2 = new Bitmap(@"C:\Users\user\Pictures\Screenshots\Screenshot_20221130_060143.png");
public Form1()
InitializeComponent();
private void Form1_Load(object sender, EventArgs e)
pictureBox1.Image = bmp1;
pictureBox2.Image = bmp2;
private void pictureBox2_Click(object sender, EventArgs e)
pictureBox2.Image = bmp1;
pictureBox1.Image = bmp2;
private void pictureBox1_Click(object sender, EventArgs e)
i asked if you were programming with a windows form or user control. you are not! if you want to discuss programming issues this is the correct forum. the code i posted shows 1 way to order images in a windows form,
you're question is about the form designer in the "Infrastructure Administrator".
i have never used it but will have to try it now.
my apologies if you feel mislead.
