AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Fatal error when trying to debug a .NET Command
2 REPLIES 2
alberto_manero_geograma
598 Views, 2 Replies
Since few weeks ago, I noticed that when I try to debug an .NET command from Visual Studio Express 2012 for Windows Desktop, AutoCAD gives me a fatal error and exists when it is loading (even before netloading the command).
I also tryed to start AutoCAD manually and do debug by attaching to the process, but that way AutoCAD Freezes and I have to kill the process (even if I dettach the process and stop debugging).
This is what I have:
  • VS Express 2012 for Windows Desktop
  • AutoCAD MAP 3D 2014
  • Windows 10 64bit
Has anyone had this problem? How could I solve it?
Thanks for your help in advance!
Luis Alberto Manero, Geograma.com
  • Windows 10 64bit
Tags (2)
2 REPLIES 2
Alfred.NESWADBA
Maybe that helps (look to Brigitte's solution >>>click<<<
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
- alfred -
Alfred NESWADBA
WOW!! That solved it!
In my case MAP 2014 has different file structure so I had to look for the ".res" file to copy it. After the change, all is OK now.
Tanks!!!!!
Tanks!!!!!
