For a long time we can recover the integer greater than 32767 (The only type of field is posible character, integer and real. The integer greater than 32767 are well managed in the integer field type object data) with the functions (ade_odgetfield) and (ade_odgetrecfield). With version Autocad Map 2017, the function (ade_odgetfield) can still return integer greater than 32767, contrariwise the function (ade_odgetrecfield) no longer returns as values between -32768 to 32767 such as 2003. The problem is that the function ade_odgetrecfield is much faster to manage many fields simultaneously.
