AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Exception When trying to create a MAP ODTable
6 REPLIES 6
lmorse
1180 Views, 6 Replies
lmorse
Hi All,
I have been searching all day but cannot find any documentation or examples. I have been trying to create a MAP (Autocad Civil 3D) ODTable, but receive an exception. I believe I have a fundamental misunderstanding of how this should work.
Exception is:
"Error: System.Runtime.InteropServices.SEHException (0x80004005): External component has thrown an exception.
at AcMapODColumnDefinition.{ctor}(AcMapODColumnDefinition* , Char* , EDataType , Char* )
at Autodesk.Gis.Map.ObjectData.FieldDefinition..ctor(String name, DataType dataType, String description)
at Autodesk.Gis.Map.ObjectData.FieldDefinitions.Add(String name, String description, DataType type, Int32 position)
at ReadDatabase.DBReader.ObjectDataTable() in C:\Users\lmorse\source\repos\ReadSurveyDatabase\ReadDatabase.cs:line 302" *
* Line 302 is the 'fields.Add("BOREHOLE NAME", "Borehole Name", Autodesk.Gis.Map.Constants.DataType.Character, 0);' line.
Here is a snippet of my code:
using Autodesk.Gis.Map.Project;
using Autodesk.Gis.Map;
using Autodesk.Gis.Map.ObjectData
Document doc = Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
ProjectModel projModel = HostMapApplicationServices.Application.Projects.GetProject(doc);
Tables odTables = HostMapApplicationServices.Application.ActiveProject.ODTables;
            if (!projModel.ODTables.IsTableDefined("Borehole"))
                try
                    FieldDefinitions fields = HostMapApplicationServices.Application.ActiveProject.MapUtility.NewODFieldDefinitions();
                    odTables.Add("Borehole", fields, "Boreholes", true);
                catch (System.Exception ex)
                    ed.WriteMessage("\nError: " + ex);
Hi All,
Exception is:
                try
Tags (1)
6 REPLIES 6
fieldguy
in reply to: lmorse
fieldguy
I would suspect "fields.Add" is the issue.  Are you following an example from somewhere?  There are several in this forum (search "fielddefinition").
I have similar code but I create a new "FieldDefinition", and add that to "FieldDefinitions", and then add the table.
Something like this:
ObjectData.FieldDefinitions tabdefs = mapprj.MapUtility.NewODFieldDefinitions();
ObjectData.FieldDefinition fd = ObjectData.FieldDefinition.Create(s, s, acgis.Constants.DataType.Character);
tabdefs.AddColumn(fd, findex);
tbls.Add(tname, tabdefs, tname, true);
lmorse
in reply to: lmorse
lmorse
Hi fieldguy,
Thanks for your reply. I have adjusted my code to do something similar, but I still get an exception, this time on the "FieldDefinition fd = FieldDefinition.Create("BOREHOLE NAME", "Borehole Name", Autodesk.Gis.Map.Constants.DataType.Character);" line:
at Autodesk.Gis.Map.ObjectData.FieldDefinition.Create(String name, String description, DataType type)
Here is a code snippet of the new code:
try
                    fields.AddColumn(fd, 0);
Hi fieldguy,
try
lmorse
in reply to: lmorse
lmorse
I was basing my code on a VBA example that I found.
lmorse
in reply to: lmorse
lmorse
I found the following post from Norman.Yuan: https://forums.autodesk.com/t5/autocad-map-3d-developer/unable-to-set-default-value-in-odtable-throu...
Based on this I changed my code to the below, but still get an exception :
var fld = FieldDefinition.Create("BOREHOLE NAME", "Borehole Name", "XXX");
fields.AddColumn(fld, 0);
fieldguy
in reply to: lmorse
fieldguy
I just tried this and my guess is that field name does not accept spaces.  I used your code and field name "BOREHOLE" and it worked.
I don't recall encountering this issue before, and cannot find documentation on OD field definition rules.
edit > I have never used the Add method of FieldDefinitions - it works as expected. I have always created a field def and used AddColumn
lmorse
in reply to: fieldguy
lmorse
Genius! That worked. Thank you so much fieldguy.
