AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Custom Autocad Map Dimension Feature
5 REPLIES 5
schikh
667 Views, 5 Replies
schikh
I need dimensions objects (like we have in Autocad) to be added to my industry model and that custom feature would be  manipulated like the Dimension in Autocad. Could you give me to information on how to code such feature or even better c++ sample code doing similar things.
SChikh
SChikh
5 REPLIES 5
fieldguy
in reply to: schikh
fieldguy
maybe you can get started with a dimension jig?
here is a link to an article from @Anonymous.yuan
https://drive-cad-with-code.blogspot.com/2020/04/jig-with-dimension.html
schikh
in reply to: fieldguy
schikh
Hi Fieldguy,
Your reply interesting, showing the Dimension Jig when editing my point feature is something I will need, do you have an Idea how to permanetly show the Dimension ? This is needed to show distances in an Industry Model map (like in a CAD drawing).
SChikh
Hi Fieldguy,
SChikh
fieldguy
in reply to: schikh
fieldguy
here's a link to another dimension jig - this dimension gets "appended" to the modelspace blocktablerecord.
https://forums.autodesk.com/t5/net/jigging-a-dimension-to-follow-mouse/m-p/11954864
if i get time later today i will modify norman's code to add the dimension tot the database.
fieldguy
in reply to: schikh
fieldguy
I was hoping you would solve this yourself.  Below is my interpretation of Norman's Move() method.  If the jig status is OK, add the dimension to the current space.
 public void Move2()
     if (!SelectEntity(out ObjectId entId, out Point3d basePt)) return;
     _entityId = entId;
     _basePoint = basePt;
     _prevPoint = basePt;
     _movingPoint = basePt;
     var offset = GetDimLineOffset(_entityId);
     var dimTextPt = GetMidOffsetPoint(_basePoint, _movingPoint, offset);
     try
         _dim = new AlignedDimension(
             _basePoint,
             _movingPoint,
             dimTextPt,
             "0000",
             _dwg.Database.DimStyleTableId);
         using (var tran = _dwg.TransactionManager.StartTransaction())
             _entity = (Entity)tran.GetObject(_entityId, OpenMode.ForWrite);
             var res = _ed.Drag(this);
             if (res.Status == PromptStatus.OK)
                 var db = _dwg.Database;
                 var cspacebtr = (BlockTableRecord)tran.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                 cspacebtr.AppendEntity(_dim);
                 tran.AddNewlyCreatedDBObject(_dim, true);
             else
                 _dim.Dispose();
             tran.Commit();
     finally { }
     _ed.WriteMessage("\nDim added");
 Are you looking for something specific to Map3D?
 public void Move2()
     _entityId = entId;
     try
             _basePoint,
             _movingPoint,
             dimTextPt,
             "0000",
             else
                 _dim.Dispose();
             tran.Commit();
     finally { }
schikh
schikh
Thanks fieldguy, exactly what I was lookin for👍
