AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Creating mpolygon fails with lisp
2 REPLIES 2
t_telintelo
600 Views, 2 Replies
Hi
I am trying to import a GML file via lisp. The problem is the entmake functie returns nil.
What is wrong with this entitie-list I can't find it. Is there a missing list perhaps??
Command: (entmake entlijst_polygon)
nil
Command: !entlijst_polygon
((0 . "MPOLYGON") (8 . "Perceel") (67 . 0) (70 . 1) (10 0.0 0.0 0.0) (2 . "_SOLID")
(71 . 1) (91 . 1) (92 . 2) (73 . 0) (72 . 0) (93 . 5) (10 -8.755 8.33 0.0)
(10 2.545 -8.33 0.0) (10 8.755 -4.4 0.0) (10 2.685 -0.24 0.0) (10 -8.755 8.33 0.0)
(76 . 1) (63 . 256) (11 232719.0 461766.0 0.0) (99 . 0) (450 . 0) (451 . 0) (460 . 0.0)
(461 . 0.0) (452 . 0) (462 . 0.0) (453 . 0) (470 . "")
2 REPLIES 2
And if you add code 100 and 210?
Your exemple modified:
(entmake
(0 . "MPOLYGON")
(100 . "AcDbEntity")
(8 . "Perceel")
(67 . 0)
(100 . "AcDbMPolygon")
(70 . 1)
(10 0.0 0.0 0.0)
(210 0.0 0.0 1.0)
(2 . "_SOLID")
(71 . 1)
(91 . 1)
(92 . 2)
(73 . 0)
(72 . 0)
(93 . 5)
(10 8.755 -4.4 0.0)
(76 . 1)
(63 . 256)
(99 . 0)
(450 . 0)
(451 . 0)
(460 . 0.0)
(461 . 0.0)
(452 . 0)
(462 . 0.0)
(453 . 0)
(470 . "")
Hello
Thanks for jour reaction. You where right code 100 was the problem.
gr. Theo
