I am reading feature geomety from sdf file and converting it to ACAD geometry.
I am having trouble to append polygon loop on a MPolygon object in many cases (function AppendMPolygonLoop()) , and i keep getting the eAmbiguousInput error, but I found nothnig on this on the net. This is my sample code:
public static MPolygon ConvertFeatureToMPolygon(OSGeo.FDO.Geometry.IGeometry geometry, Style style, ref bool error) { MPolygon mPolygon = null; Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor; Database db = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database; try { mPolygon = new MPolygon(); MPolygonLoopCollection mPolygonLoopColl = new MPolygonLoopCollection(); MPolygonLoop mpolygonExteriorLoop = new MPolygonLoop(); var polygonGeometry = geometry as OSGeo.FDO.Geometry.IPolygon; var exteriorRing = polygonGeometry.ExteriorRing; for (int i = 0; i < exteriorRing.Count; i++) { var position = exteriorRing[i]; mpolygonExteriorLoop.Add(new BulgeVertex(new Point2d(position.X, position.Y), 0)); } mPolygonLoopColl.Add(mpolygonExteriorLoop); int numOfInnerLoops = polygonGeometry.InteriorRingCount; for (int i = 0; i < numOfInnerLoops; i++) { MPolygonLoop mPolygonInnerLoop = new MPolygonLoop(); var innerRing = polygonGeometry.GetInteriorRing(i); for (int j = 0; j < innerRing.Count; j++) { var position = innerRing[j]; mPolygonInnerLoop.Add(new BulgeVertex(new Point2d(position.X, position.Y), 0)); } mPolygonLoopColl.Add(mPolygonInnerLoop); } foreach (MPolygonLoop loop in mPolygonLoopColl) { mPolygon.AppendMPolygonLoop(loop, true, 0.02); } try { mPolygon.Layer = style.Layer.Name; } catch { ACGHelperMethods.CreateLayer(style.Layer); mPolygon.Layer = style.Layer.Name; } Pattern pattern = style.Pattern; if (pattern != null) { mPolygon.SetPattern(HatchPatternType.PreDefined, pattern.Name); if (pattern.Color.Index != 0) { mPolygon.PatternColor = Autodesk.AutoCAD.Colors.Color.FromColorIndex(ColorMethod.ByAci, pattern.Color.Index); } else { mPolygon.PatternColor = Autodesk.AutoCAD.Colors.Color.FromRgb((byte)pattern.Color.Red, (byte)pattern.Color.Green, (byte)pattern.Color.Blue); } if (pattern.Angle != 0) { mPolygon.PatternAngle = pattern.Angle; } if (pattern.Scale != 0) { mPolygon.PatternScale = pattern.Scale; } if (pattern.Space != 0) { mPolygon.PatternSpace = pattern.Space; } } mPolygon.BalanceTree(); } catch { mPolygon = null; error = true; return mPolygon; } return mPolygon; }
Solved by tamara. Go to Solution.
Are you able to create this mpolygon in Map using acad tools (command "mpolygon")? If yes, create 1, explode it, and check if acad changed the direction on 1 of the polylines.
I would try adding the interior loop in the opposite direction. IIRC the definition of polygons with islands is controlled by direction. Exterior is clockwise, interior is counter-clockwise (kind of guessing here - it's been awhile).
Actually, I just needed to set
mPolygon.AppendMPolygonLoop(loop, true, 0.00);
to
mPolygon.AppendMPolygonLoop(loop, false, 0.00);
so that crossing loops don't get excluded. Turns out that I had many features in the database with crossing loops, so that was the problem I overlooked.
I'm glad you were able to solve it. I saw your post in the Map 3D forum. IMO you will never get a response from Autodesk on Map 3D procedures. You will have better luck in the OSGEO forums. I believe the future of Map is there - not here.
