AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
AddRaster VB function
2 REPLIES 2
694 Views, 2 Replies
I have somme problems to use this VB function:
ADDRASTER
I don't know really how it works
I know there are 4 parameters:
image file name,
Insertion point,
Scalefactor,
rotation angle.
Does somebody has already used it? and can give me some information about it ?
For instance, what I have to insert as an insertion point? (I am only allowed to type 1 parameter and usually a point has X and Y coordinates).
What are the units of the parameters?
If somebody has a small program that can show me with an example how this function is working, it would be great !
Caroline
ADDRASTER
image file name,
Insertion point,
Scalefactor,
rotation angle.
Caroline
2 REPLIES 2
From the Help:
[code]
Sub Example_AddRaster()
' This example adds a raster image in model space.
' This example uses the "downtown.jpg" found in the Sample
' directory. If you do not have this image, or if it is located
' in a different directory, insert a valid path and file name
' for the imageName variable below.
Dim insertionPoint(0 To 2) As Double
Dim scalefactor As Double
Dim rotationAngle As Double
Dim imageName As String
Dim rasterObj As AcadRasterImage
imageName = "C:/AutoCAD/sample/downtown.jpg"
insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0#
scalefactor = 1#
rotationAngle = 0
On Error Resume Next
' Creates a raster image in model space
Set rasterObj = ThisDrawing.ModelSpace.AddRaster(imageName, insertionPoint, scalefactor, rotationAngle)
If Err.Description = "File error" Then
MsgBox imageName & " could not be found."
Exit Sub
End If
End Sub
[/code]
Scott
From the Help:
[code]
scalefactor = 1#
rotationAngle = 0
Exit Sub
End If
End Sub
[/code]
Scott
1005592820
我有一些问题,我想问一下,我不能在CAD文件中插入lilin.jpg的图片和代码
Set ohost = GetObject("AutoCAD.Application.19") '检查AutoCAD是否已经打开
If Err <> 0 Then '没有打开
Err.Clear
Set ohost = CreateObject("AutoCAD.Application.19") '打开CAD
If Err Then
MsgBox Err.Number & ":" & Err.Description '打开失败
Exit Sub
End If
End If
Set odaApp = ohost.Application
ohost.Visible = True
Set odoc = ohost.Documents.Open(filePath)
Set acadDoc = ohost.ActiveDocument
'gr 测试
Dim insertPoint(0 To 2) As Double
imageName = "D:/Siemens/signpic/lilin.jpg" insertPoint
(0) = 5#: insertPoint(1) = 5#: insertPoint(2) = 0#
scalefactor = 1#
rotationAngle = 0
' 在模型空间中创建光栅图像
Set rasterObj = acadDoc.ModelSpace.AddRaster(imageName, insertPoint, scalefactor, rotationAngle)
Exit Sub
End If
odoc.Save
odoc.Close
End Sub
Err.Clear
If Err Then
Exit Sub
End If
End If
'gr 测试
scalefactor = 1#
rotationAngle = 0
' 在模型空间中创建光栅图像
Exit Sub
End If
odoc.Save
odoc.Close
End Sub
